Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
My sanibest system is working but not pumping the water - any suggestions?
  • 4 Answers
Possible blockage in dis charge pipe, not something i'd like to investigate myself!!
Posted on Jan 27, 2009
Saniflo says the bottom of shower should be 8" from floor. But what is the lowest the shower can be and still function ok?? Will 5" give enough slant? Or, how high does the water get in the sanibest u
Sorry but they give you 8" for a reason, they did the testing etc. You might get by at 5" but that will probably just get by and limit the service life.
Nov 27, 2014 | Saniflo Plumbing
Macerating pump comes on by itself
Either the toilet is leaking water through or the check valve on the outlet pipe is not seating completely and allowing water to return to the tank.
heatman101
Apr 20, 2011 | Saniflo Sanibest Grinder Pump Only 013
I have a saniflo macerator toilet system and when flushed, the pump does not immediately come on and the water level rises up pretty high. only then the pump comes on for a second or two but the bowl does...
Did you put an 1 1/2" vent pipe? It must be vented to the open air. Air must flow in and out of the vent pipe at all times so it can work properly. I had the same issue but after removing the cheater vent from the vent pipe it solved my problem. They do not recommend using an air admittance valve, cheater or mechanical vent on the vent pipe, as it only allows air to flow in or out.
Jun 09, 2010 | Saniflo SANIBEST Pump Macerator Grinder...
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
A new saniflo working perfectly for first week has now stopped working. the unit does not run at all
y have a reset butto which may have pinged out try resetting it or it may have overloaded due to a blockage never put paper or towles in them water expanps them and causes this problem
Aug 02, 2009 | Saniflo Sanibest Grinder Pump Only 013
Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
May 13, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
374 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
