Question about Maytag Washing Machines
Maytag LAT9206AAE won't stop filling - Maytag Washing Machines
marka19
  • 1430 Answers
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 20, 2011
  • 87 Answers
SOURCE: I have a maytag LAT9593AAL;
Your problem is the lid switch assy. Part # 22001682
Posted on Jun 05, 2011
  • 6277 Answers
SOURCE: Maytag Altlantis.
If you have not done so already, check the supply socket with a kettle, for instance. If the socket is not working check your fuse/breaker box. If a breaker is out/ fuse blown and you reset/replace please remember that these happen to protect the parts of the washer which are not faulty. It could happen again ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 09, 2011
  • 81 Answers
SOURCE: Maytag heavy duty super capacity
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Posted on Jul 16, 2011
kel1guy2002
  • 3740 Answers
SOURCE: My Maytag washer Model:LAT6800AA won't
Is your model number correct? Or is this the LAT8600AA? (typo?)
This wiring diagram is typical of most every LAT model as far as the water fill & agitation circuits:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28437491&pkw_=basket&model_id=26594&NewWindow=1
Can you select spin and have the maching spin?
Here is how to test the motor:
You can sacrifice an extension cord to build this test harness.
The direct connections for a motor run test involves making a test cord. The test cord will have 4 connections (2Y connections) I.e. each of the power / cord wires is split off to 2 terminal on each wire. This will run the motor. Reversing the motor is done by switching wires B and C
If the motor runs during this test. it is sure looking like the timer is bad.
If you can not see the end of the D wire it Connects where the BLACK wire was.
All wiring harness wires from the machine have to be removed for the test. Draw your own diagram for the wires you removed!!!!!!
Kelly
Posted on Jul 29, 2011
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
The water won't stop filling up the tub causing it to over flow.
it could be the pressure chamber is blocked up with old hard soap or the pressure switch is jamed
May 28, 2012 | Maytag Neptune FAV6800AW Top Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Maytag heavy duty super capacity washer - stopped mid cycle. Won't drain water. Won't agitate. Water fill function works. Any ideas what to check? Do you know where the fuse is located?
Jul 16, 2011 | Maytag Washing Machines
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
