Question about Dell Inspiron 6000 Notebook
We have an Inspirion 6000 with this problem and we've discovered if you pull the power cord out very slightly and lift it upwards, the charging icon appears in the system tray.
    Sergeant:
  • 180 Answers
My friend has a latitude d600 that has the power port messed up in the back of the computer. i got him this thing, some people call it a docking station some people call it a port replicator, but you dock the computer to it and then you plug your power into the docking station and it charges it that way. you get extra usb ports and stuff like that and there is no repair involved. i dont know if you would want to try something like that maybe.
Posted on Jan 23, 2009
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
Can't turn on my mini netbook inspirion - help
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
How top remove seats
  • Lift the rear of the passenger seat's cushion to find the screw that secures the seat to the rear fender. Use a 5-mm Allen wrench to remove the screw.
  • Lift the rear of the passenger seat slightly and pull it away from the rider's seat.
  • Use the 5-mm Allen wrench to remove the screws from the rear of the rider's seat.
  • Lift the rear of the rider's seat upward slightly. Pull the seat back until the tabs on the front of the seat separate from the motorcycle's frame.
  • Mar 27, 2011 | 2005 Suzuki Boulevard C50
    I have a Laptop, Dell Inspirion 9100. Recently it
    I would suggest testing your laptop with another adapter, first. Then you'll know whether to replace the adapter, which is priced around $50.
    Aug 01, 2009 | Dell Computers & Internet
    Dell Laptop power supply charges sporadically
    when i replug my Dell laptop ,the charging system does not display.
    Mar 13, 2009 | Dell HQRP Replacement Laptop AC Adapter /...
    Battery charging port issue
    This sounds like a connection issue inside the computer. What this means is that the soldering inside your computer at the point of connection is probably weakened, and you will need to take your computer in for repair if you are not very good at soldering. Unless you are VERY talented at soldering, I do not suggest doing this repair yourself as you can damage or ruin your computer.
    Alternatively, there may be a loose pin or something of the sort at the point where you plug your adaptor in. Again, this is something that needs to be looked at by a professional.
    Jan 23, 2009 | Dell Inspiron 6000 Notebook
    Dell inspirion 6000 battery/charging problem
    Also, check to make sure that you have a good connection between the laptop and the charging cable at the power port on the rear of the laptop. We have an Inspirion 6000 with this problem and we've discovered if you pull the power cord out very slightly and lift it upwards, the charging icon appears in the system tray. Appears to be a fractured connection inside the laptop at the power port. Changing chargers does not make any difference.
    Nov 18, 2007 | Dell Inspiron 6000 Notebook
    Dell Inspiron 6000 Notebook Logo
    96 people viewed this question
    Alun Cox
