Hello, I have BRX1121 Altec lansing speakers. I was trying to connect the 9 pin connector to subwoofer and broke 1 pin in the connector so now only left speak works. Is there any way to fix this? Thanks
2 Suggested Answers
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
Is there a way to use the Altec Lansing VS4121 Subwoofer as a stand alone?
Normally these low end system components depend on each other and cannot be interchanged with components from other system. So if one of the components (subwoofer or right control satellite speaker) breaks or gets lost the whole system is unusable...
I was in the same situation. Got a subwoofer from VS4121 without original satellite speakers. I acquired satellite speakers from Altec Lansing 251 which used same connectors but the internal wiring was different and incompatible. Speakers are also glued together so it is impossible to open without damaging it. Obviously there is no service documentation anywhere..
But if you like electronics you can try to make something based on the information below:
Altec Lansing VS4121 connector pinout:
Take the male connector (from right satellite speaker) and number pins in first row from left to right as 1-3, pins in the second row as 4-7, pins in the bottom row as 8-9 and the circle enclosure as 0. Then:
0 - Ground
1 - Speaker Right
2 - Treble (seems just like voltage control but may need to be confirmed: Min=0V; Max=voltage from Volume control Pin 9)
3 - Head Set Right
4 - Bass signal (not sure what the exact original design is as I have not opened the speaker) But seems like they use 50K potentiometer and some sort of RC low pass filter configuration. When potentiometer is set to Min it is shorted with ground. When set to Max it is taking signal from Right and Left Head Set (pins 3 and 5) combined through some larger resistors and low pass filter.
5 - Headset Left
6 - Ground for Headset (grounds 0 and 6 seems to be connected in the subwofer but within the right satellite speaker they seem to be isolated with separate leads to sub)
7 - Power ON/OFF. When OFF or headset jack plugged then 0V. When ON and headset jack unplugged then 5V
8 - 5V Power in
9 - Volume (min=0V; max=5V). It seems they use 50K potentiometer but probably anything >10k should work.
At minimum for standalone subwoofer you will need to implement:
- Power On/Off (switch between pins 8,7)
- Volume control 50k potentiometer (probably anything between 10k and 50k will do) between pin 7 and 0 with variable output to pin 9
- Bass control - join two resistors R (I used 7k) and call this join point A. Attach other ends of the resistors to pins 3 and 5 respectively. Attach 50k potentiometer (I used 10k) between point A and ground 0. Attach Variable pin of the potentiometer to pin 4 (Bass input signal). Attach capacitor C between Pin 4 and Ground pin 0 (I used Electrolytic 1uF with negative end to ground) . Resistor R and capacitor C should make simple passive low pass filter (Google for formula) that should short any frequency higher than 80-120Hz to ground and feed frequencies lower than 80-120Hz to pin 4.
PS: I managed to hack 251 control satellite speaker to somewhat work with VS4121 Subwoofer but that is another subject. All electronic parts were salvaged from old broken TV so total cost was $0 but took several days of tinkering for speakers that I could buy used for $10-20 :)
Jun 25, 2012 | Altec Lansing VS4121 Speaker
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
74 people viewed this question
 Grubhead
Grubhead
