Question about Indesit W 123 Front Load Washer
Indesit w123 It seems to get stuck at the beginning of a wash cycle. No matter what number we start it on - for example 8 - it starts ok the drum turns etc.. but just seems to stay at that point indefinately. I do try to move it on by hand but the timer knob starts to move around the clock until its back where the programme thinks it should be. i.e. at the start number 8. It doesn't seem to even get to the point where the element is turned on and the water starts to heat up. I can only get it to drain away if I switch it off at the wall turn the button to reset and wait for the click suggesting the door is now unlocked. I can then switch the power on and turn it to drain which it then does. help!!! thanks in advance Nicki
  • nicki webb Jul 09, 2007
    ok will try that - so are you suggesting that it will only move thru the cycle when the water reaches the set temperature. Cos that would kinda make sense but I really dont know too much about these things. really appreciate your help
    thanks
    Nicki
    thank you - the element had blown so a new one is on its way!!!
    brilliant
    thanks again
    Nicki
    President:
  • 1,462 Answers
Possibly the heater. take bottom back panel off and check continuity across the heater bottom rhs
Posted on Jul 09, 2007
My 1wd7145k (uk) has stopped working mid cycle, I have restarted and it fills with water ok but does not start to spin but continues to count down on the program timer. the motor does not spin and I
May be the rubber belt is gone open the screws behind the washing machine and check if the belt is worn out or cut replace by buying the belt of the same code number printed on the belt
Nov 15, 2014 | Indesit Washing Machines
Indesit W123 drum not moving. Will turn freely and quietly both directions if spun by hand. Sounds like going through cycle and dial turns as is going through programme. Made a whirring noise when ini
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 20, 2013 | Indesit Door Handle Kit for W123, W133,...
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Dial spinning on W123
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 29, 2008 | Indesit W 123 Front Load Washer
Indesit W123 - 8 Flashes Error Code
thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Oct 26, 2007 | Indesit W 123 Front Load Washer
Indesit w123
the holes above the drawer may be blocked. remove the drawer and scrub the holes with a stiff washing up brush rinse away then try again.
Jun 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
262 people viewed this question
Top Indesit Washing Machines Experts
jimorris77
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
