Question about LG WFT1071TP Top Load Washer
Error code D3 after a minute
LG WF-T7015TP Top LOader - No matter what cycle is used the machine stops after a minute and displays error code D3.
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
  • 489 Answers
SOURCE: LG WD-1021-WF Front Loader Washing Mashing
Replacing the door seal is not an easy task.  You will need to get 2 special tools from LG to make it as easy as possible.  The spring loaded clamps are very hard to put on because the springs are so strong.  Once you get the special tools, remove the front clamp off the door seal.  Pull the seal off the lip to gain access to inner seal clamp.  Remove the inner clamp and pull off the rubber door seal.  Just reverse the procedure when reinstalling the new seal.
Posted on Jun 26, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
Hi I have a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
PRESSURE SENSOR ERROR // Water level pressure switch error
The manufacturer has assigned this error or fault code to indicate that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 04, 2016 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
When I Fill my washing machine (Top loader Lg Wf-T7015tp), it Makes a Funny Noise and die when I start the program.Is it the Capasitor or is it the v-belt tension?
If the noise is only when this function of filling, and if you are only using one of the two fill valves, may be due to the magnets of the inlet valves of the water, which are activated in filling and are disabled when you start the program. that noise is normal unless it is very strong and is the preamble to the damage of the two valves.
Nov 10, 2014 | LG Washing Machines
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
What is the problem if the LG Fuzzy WF-T1330TP top loader shows error code PE.
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Apr 08, 2011 | LG Washing Machines
I am getting error DE in my washing machine, need solution for this. Kindly give me the service error code for LG WF-T7516HN top loader
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Dec 03, 2010 | LG Washing Machines
I have a WF-T556 top loader with a de error. Should there be a magnet on the lid of the machine??
There sure should be....why, because mine stopped working as well. Found magnet inside machine after getting rid of water on spin cycle (thankfully it still allows the water drain to occur). Put magnet back on and hey presto, all good.....if only I had taped it on as 5-6 washes later and it has fallen off and I can't find it - hopefully a standard magnet will be enough to fix from shops - I am sure LG or proper repair place sells them for a fortune :(
Jul 04, 2010 | LG WFT1071TP Top Load Washer
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
432 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
