Question about Omron E2K-C25MY1 Proximity Switch
Proximity Switch faulting out irregulary
What: Omron E2K-C25MY2 Capacitive Proximity Switch
Problem Summary:
I have the switch wired in series with a manual on/off switch to a time delay that controls a motor starter.
When I turn the manual switch to the off position and back on, the light on the proximity switch is dull red. I have to wave my hand in front of the switch a few times for it to become bright red and function properly.
Also, after the light becomes bright red, the switch will work properly for 50+ cycles and then become dull red again, requiring me to wave my hand in front to reset it.
This condition has occurred on 2 brand new switches and I've tried wiring into both sides of the manual switch.
Please help.
Thank you,
Stephen
Mobile, AL
    Problem Solver:
  • 12 Answers
I dont know what the inviroment is but it sounds like a plant of some sort, the inviroment is important and the electrical service is important. There could be serveral issues here. I would check the electrical service for phase balance and investigate harmonics created through electronics.
Posted on Jan 25, 2009
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
1999 BMW 318i engine fan stays on. I have already checked the thermo switch & the a/c pressure switch along with the wiring to the engine ECU & have found no fault. The cause of the fault seems to be the...
when you write that you had found no fault with the switches, what were you trying to find? I'm not familiar with the wiring in your car, but in my vehicle everything is in series and parallel relays. So if one drops out or malfunctions, the fan does not function. Most cars keep the fan running after the car has been stopped from running because of residual heat in the engine. If it runs beyond 15 minutes I would start to be suspicious.
Oct 04, 2013 | 1999 BMW 328 Series
6 Volt dc 4w charger for Omron blood pressure unit
You can use a multi voltage mains adapter for your Omron. These are available at electronic stores ot on the Internet. Make sure it is a DC adapter and switch to 6 volts also make sure the power connector is set correctly to the polarity of the Omron power socket.
Nov 30, 2012 | Omron Health & Beauty
Omron bp710
I use Omron blood pressure monitors and I can say that they are up to the mark. Their readings are very accurate and have not caused any problems so far.
Aug 03, 2012 | Omron Automatic Blood Pressure Monitor w/...
Sequence. Switch on--"Left wrist do
There are some known issues with this model. You will need to contact Omron directly. Here is a link to the contact information.
Sep 08, 2011 | Omron Hj 720ITC Advanced Pocket Pedometer
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
1998 bmw 740 il will not start....lights, radio come on, doors lock and unlock, not sure why it won't strart seems to be locked, is it the alarm system?
Could be the alarm system, the key proximity sensor, etc.
But start with the easy stuff first, like the neutral safety switch, etc.
If it does not start in park, try neutral.
To see if the starter is ok, jump the large terminal at the solenoid, to the small solenoid energizing push on terminal. (make sure in park or neutral, and parking break engaged!)
It is possible to simply wire a momentary contact switch and bypass all the alarm stuff.
Jan 24, 2011 | 1998 BMW 7 Series
OMRON RS4602 EPOS - CG file full, cannot clear screen and cant find any info anywhere about how to, any ideas?
Some Omron cash register manuals here too:
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
omron RS-3010E Programming
omron RS-3010 User(R) Service(R) Programming(R)
omron RS-3410 User(R) Programming(R)
omron RS-3460 Programming(R)
omron RS-4601 Programming(R)
omron RS18 Programming(R)
omron RS25 Managers guide(R) Programming(R)
Jan 02, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
Omron E2K-C25MY1 Proximity Switch Logo
810 people viewed this question
Top Omron Electrical Supplies Experts
Steve
Gene Haynes
Are you an Omron Electrical Supply Expert? Answer questions, earn points and help others
