Question about Cardo Systems Cardo Scala Rider G9
G9 usb will not work
When I plug in the USB it says device not recognized
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
When i connect my pen drive to the pc,it says "USB Device Not Recognized. One of the USB devices attached to this computer has malfunctioned and Windows does not recognize it"
please you can try a diferent usb port.
if that dont work, then shut down and resart your system with device plugged in.
if it still don't work, reinstall driver if device isn't plug and play
Jan 09, 2011 | Computers & Internet
Usb ports not recognized
Did this suddenly start to occur? Were they working before? If so, it is very simple - shut down computer, remove the battery and unplug any power source, wait a couple of minutes and reassemble and power up. Wala! I read all kinds of complicated instructions, started with the simple, and problem solved.
Feb 22, 2010 | Computers & Internet
USB not recognized during printing and scanning
Some motherboard or operating systems have problems if you leave usb devices plugged in. They don't recognize that the device is still there and ignore it. These are referred to as "Legacy USB devices". There are a couple of things to try.
Make sure the problem isn't the printer if you can. If you have another computer just plug it in long enough to for the operating system to recognize something has been plugged in.
On this computer giving you the problem. unplug the usb cable and insert into a different USB port. Usually this is enough to "fix" it and make it usable.
Next is to unplug the usb and reboot the computer a few times. Then insert into a different usb port.
Past this point if it still isn't working then you need to go to control panel-system-hardware manager-usb devices and delete all entries under the usb header. Then reboot. This forces the operating system to find all the usb ports and reinstalls the drivers. Then plug in the usb and it should work again.
Oct 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Usb is not recognizing plug-in
may the usb device in your bios is disable. you must enable the usb device in your bios to recgnice your usb. you must enter to the bios setup to config. the usb configuration.
Apr 30, 2009 | Computers & Internet
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Windows does not recognize USB connection to the SpeedStream 6520- malfanctioning
try using different USB port. if the it is unknown device. means the machine didn't recognized the device. you may have to install the device driver. (windows is a funny thing).
Nov 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
USB External storage device not working properly
please update the USB Drivers and if that Doesnot Work then Update the BIOS of you Computer from the Manufacturers Web site
Nov 01, 2008 | Dell Computers & Internet
USB Drive
Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
Cardo Systems Cardo Scala Rider G9 Logo
291 people viewed this question
Top Cardo Systems Radio Communications Experts
eradiostore
eradiostore
Are you a Cardo Systems Radio Communication Expert? Answer questions, earn points and help others
