Question about EXPANSYS iTamTam
Itam tam control - EXPANSYS iTamTam
I oder a kangertac to aliexpress the traking infomation my itam showing 'held by custom ' what that mens I will get my itam or I want call what I shut do ?
it means that the department of customs and excise is holding your item and is inspecting it for illegal substances, origin biological or disease inspection
when they are satisfied that it meets the import and protection act it will be forwarded onto the transport for shipping to your address
if you have concerns contact the customs department direct and make inquiries
Feb 28, 2016 | Watches
Can you help me with my universal remote control
Most universal remotes have a feature that allows them to seek the code automatically. I suggest you read your instructions and try that.
If you have no success there is usually an advice line. I have heard the staff are very helpful.
Feb 25, 2015 | Universal Remote Control Televison & Video
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Tam full?
What model Telephone Answering Machine (TAM)?
May 09, 2013 | Binatone Lands Phones
Cannot find @ and # symbol on HP mini Vivienne Tam Keyboard
Sounds like you're setup for England rather than USA in Windows settings, at least the keyboard settings.
Apr 09, 2010 | HP Mini 1000 Vivienne Tam Special Edition...
When having phone conversation fax goes off...how do I fix this?
On fax machine there should be a answer mode settings on them. For an example phone, fax, or tam mode. The tam mode is when the fax machine will pick up if there is incoming fax automatically if hooked up behind the answering machine. Try doing some troubleshooting, by changing the it to phone only, and see if that works. Then if that works try the tam mode.
Aug 11, 2009 | Canon MX700 Office All-In-One InkJet...
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
EXPANSYS iTamTam Logo
Top EXPANSYS Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an EXPANSYS Audio Player and Recorder Expert? Answer questions, earn points and help others
