Question about Xerox Phaser 6100/BD Laser Printer
What windows 8 driver will work for a Xerox Phaser 6200?
I have a new laptop with windows 8 and need to install a print driver for my Xerox Phaser 6200, which does not have a windows 8 driver.
  • 2072 Answers
SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Posted on Jul 12, 2008
  • 49 Answers
SOURCE: xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Posted on Mar 31, 2009
Geekman
  • 32281 Answers
SOURCE: Xerox Phaser 6100 vs Windows 7
Try using the Vista driver, it may work and may not have all the functions that was available under Vista.
Posted on Jun 10, 2010
  • 5 Answers
SOURCE: need xerox phaser 3124 printer driver compatible for mac 10.6
go to www.samsung.com download and install mac driver for ML-2510 works like a charm for xerox phaser 3124
Posted on Jun 22, 2010
SOURCE: I'm trying to uninstall Xerox
I'm trying to install Xerox Phaser 3100MFP & get Error 2343! Specified path not found. How am I to solve the problem? I want to install new driver for XP.
Posted on Jul 01, 2011
Phaser 6010 not printing windows 7 64 bit
If this printer was installed from the network its possible the windows 8 driver was incorrectly loaded on the server or from the disk. Happens a lot. If you have access to the change driver tab under printer properties, change it to a windows seven driver. Those can be found at www.xerox.com, clicking support and drivers and then typing in the model number and clicking on driver/downloads. You can at this point either let the automated Install handle it, or cancel after it has extracted to c:\xerox and manually change the driver as mentioned above. PS and pcl make no difference, however I highly do Not recommend the global driver for this little guy.
Sep 06, 2013 | Xerox Printer Division Xerox Phaser 6010/N...
Since updating to Apple OS X Lion I cannot print using my Xerox 6200DP
Have you updated the Printer Driver for OS X.
Try uninstalling the existing Driver and reinstall a new one from the link below.
http://www.support.xerox.com/support/phaser-6200/downloads/enus.html?operatingSystem=macosx&fileLanguage=en
If you need any further assistance then please just ask.
Aug 19, 2011 | Xerox Computers & Internet
I by new laptop with windows 7,but I can't install
You can try going to the link below and download the latest drivers directly from Fuji Xerox This link will bring you to the download page for the Fuji Xerox Phaser 3124 for windows 7 install this driver and you should be all set
http://www.support.xerox.com/support/phaser-3124/file-download-fx/enau.html?operatingSystem=win7&fileLanguage=en_GB&contentId=105996&from=downloads-fx&viewArchived=false
Jun 15, 2011 | Fuji Office Equipment & Supplies
Jun 10, 2010 | Xerox Phaser 6100/BD Laser Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
121 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
