Question about Microsoft IntelliMouse
Want to open and clean Intellimouse w/ sticky left click button
Intellimouse model 1004 no external screws
left mouse click random
  • 24 Answers
There's 4 sliders on the bottom of the mouse. Remove the 2 feet closest to the optical sensor on the bottom. You'll find 2 phillips screws there. Remove those then pry the mouse open.
Posted on Apr 17, 2009
  • zapiain_g
    zapiain_g Jan 22, 2013
    I follow the steps that you said, I blow air inside of the mouse and now is working well, thanks you very much
    Problem Solver:
  • 7 Answers
You need an arsol can of air, and a simple wash cloth with water, no alochol.
the air cleans the contacts, the cloth cleans the entire mouse.
do not open the mouse. contact microsoft for further instructions if this does not work.
It has worked great on mine.
Posted on Jan 31, 2009
  • 1 more comment
  • fmr888 Feb 08, 2009
    check the settings in control panel for you mouse and see how the buttons are set and how your click is set up. reinstall your driver if you think that is not a problem. how old is the mouse?
  • fmr888 Mar 01, 2009
    why is this Inappropriate
Hello! I dont need to open my Intellimouse to clean it, but I find way to open....On bottom (where is red LED) there is four plastic "foots" and under are two screws...:)) Unscrew it and open......
Also I have problem with usb connector (no contact - broken wire(s))......So:
1) Open black connector - whatever you like, but dont broke it...
2) Cut wires till you have contact
3) Resolder wires to usb connector (Black-Green-White-Red) and ground to metal
Works!!!
Posted on Mar 27, 2015
Double clicking, left button
Hello, if the mouse is double clicking randomly means the mouse button or button soldering are broken, maybe you might want to try opening it up and resoldering the mouse button, if it doesn't work you can use an old mouse button that fits the space and solder that one in the mouse that's having problems, reassemble and see if it works, the good news is that most of the time it does.
Mar 30, 2013 | Logitech Trackman Marble FX Trackball
Left button stop working
Try cleaning it if you can. otherwise get a new mouse.
Mar 09, 2010 | Microsoft Wireless IntelliMouse Explorer
Sticky mouse button
my friend you can open your mouse, first you need to find the screw in your mouse. Then after you find the screw used a screw driver to open it and in order to open you have to remove all screw. then When you open your mouse kindly clean it remove the mouse board and blower it to dry also make the entire mouse dry before you back the mouse from it proper formation.
Thanks
Jul 01, 2009 | Microsoft SideWinder Mouse - Mouse - laser...
Up is down, down is up!...
Friend go to the mouse settings then change the scroll direction icon. click setting then mouse settings then diplay of mouse controls and scrolls
Apr 28, 2009 | Microsoft Wireless IntelliMouse Explorer
Right click button no longer working
Go to Control Panel and click on the Mouse icon. When the mouse properties comes up click on Buttons tab and check to see if the Left Button is set to Default. Hope this helps. Bud
Nov 28, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Mouse buttons not working
try unscrewing the mouse and see if the mouse clips are engaging on the sensors or clips
Feb 08, 2008 | Microsoft Wireless IntelliMouse Explorer
Right mouse button, wireless intellimouse explorer 2.0
the right and left buttons are controlled by a switch you need to replace the switch
Dec 07, 2007 | Microsoft Wireless IntelliMouse Explorer
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Microsoft IntelliMouse Logo
2,854 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
