Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series Vacuum
My vacuum is not sucking.  Will a filter change help?  The machine sounds as though it is working, overtime even!  thanks for the help. my e series has lost alot of suction what can i do?
  • 24 Answers
It's plugged!
If it happened suddenly, you have a jam somewhere. Unhook the hose to see if it's in the hose or the unit.
If it happened over time then it's likely dirty or full. Wet dirt can accumulate near the blower and inhibit suction. Cleaning the filter is almost always a good idea.
Best to you, Jidza
Posted on Jan 23, 2009
Where is the motor on the dc18
Hi there, it's Jack at Dyson.
If your DC18 is making an unusual sound along with a change in pickup performance, it's likely you have a blockage somewhere. Our online Support guide should help you locate and clear this:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If your vacuum's filter hasn't been washed recently it's also a good idea to do this. DC18 has one washable filter engineered to last the lifetime of the machine in normal use. This should be washed at least once every 3-6 months using cold water without detergent as shown in the video below. Make sure the filter is completely dry before replacing it - this could take at least 12 hours:
Please note, the post-filter is engineered to last the lifetime of the vacuum without maintenance, and should not be washed as this could cause damage.
Following these steps should resolve the issue, but if you would like some further help from our experts, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 10, 2014 | Dyson Dc-18 "slim" Upright Model...
Power nozzle motor not working on my rainbow e2 vacuum?
Check plugin on the power nozzle and poles there may be some thing blocking connections
Dec 28, 2013 | Rainbow E series Canister Wet/Dry Vacuum
I have a Karcher WD 3.500 P wet dry vac. First ? when vacuuming dirt off floor do I always need the bag or is the cartridge primary filter ok.. I clean it regularly. Second problem. I went to turn on...
The bag is part of the filtration design of the machine. Using it will not only make your primary cartridge filter last longer, but make the vacuum suck more efficiently & make your vacuum as a whole last longer.
You can bypass the switch to check if the motor is okay.
More often than not an intermittent operation of a machine is actually due to a break in the power lead. This is not always apparent externally though. You may need to get this checked by a qualified / certified person.
Mar 29, 2017 | Vacuums
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Overflow .. HELP
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Not sucking up when i put the canister on or when i try just the hand held attachments
There is a cup inside and up above the cup with other filters. theres more then just one filter even though it has a cup for dumping.
Sep 22, 2009 | Vacuums
Rainbow water not spinning
All Rainbows - remove the hose and turn it on without the hose plugged in - if works better - hose is clogged
If it works bad even with the hose out:
E-series Rainbow - take HEPA filter cartridge and try then. If helps - you need new HEPA (you can get it here)
SE Rainbow vacuums - remove exhaust cap
and you may find a dirty sponge in there - just remove it and it may help.
If none of that made any difference - you may need it to be checked. If you do not mind shipping - our info is HERE
Feb 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
MY hooverselfproweled windtonel sound like an air craft getting ready to take off and lost alot of sucking powers. I had it serviced at a local store. It wasn't right when go it back. All belts and...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761558
Generic problem for all Vacuums
MY Hoover self propelled WindTunnel sound like
Posted by nonaroberts on Jul 09, 2008
My Hoover self propelled WindTunnel sound like an air craft getting ready to take off and lost a lot of sucking powers. I had it serviced at a local store. It wasn't right when go it back. All belts and filters where changed.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Even though the belts and filters have been changed it sounds to me that you may have broken a fan and when that happens it sounds like a air craft and it is very loud. You don’t want to continue to use it that way, a fan would cost between approx $10.00 to $20.00 plus labor to install B4 it does anymore damage otherwise the vacuum should be just fine if you just had it serviced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Rainbow E series Canister Wet/Dry Vacuum Logo
272 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
