Question about Carrier 38CKC042 Air Conditioner
Diagram for 10kw heat pack for carrier furnace
I need a diagram for a 10kw heat pack on a carrier furnace
  • hsprout Jan 23, 2009
    a diagram for 10kw heat pack on an electric furnace kfceh2601c10 serial:1107va84011
  • Perry Putnam
    Perry Putnam May 11, 2010
    When asking for information on parts etc. You need to give the model and serial #'s as well. What do you need the diagram for? Maybe we can help with out the diagram.
    Scholar:
  • 144 Answers
I hope this helps
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/wd-fa4c-01.pdf
Posted on Jan 23, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Heater not heating enough
Electric furnaces have strip heat inside of them. Depending on the model, size, etc, is how much heat the system can provide. Many times, if the system has worked in the past and started to have problems later, it's because you have lost half or more of your heat strips. They come in different sizes, 10kw, 15kw, 20kw, but ran on different contactors. So if you have a tripped breaker, faulty heat sequencer, etc, you can still have heat, but not the full amount. I strongly suggest any electrical related problems be look at by a qualified technician when dealing with air handlers. Hope this helps!
Dec 08, 2013 | Heating & Cooling
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like thathttp://www.scribd.com/doc/20861415/Carrier-58pav-Service-Maint i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
HOW DO I WIRE A HEAT STRIP IN MY HEIL CENTRAL AIR CONDITIONER ?
Do you have power to the unit for the new heat strips? what size strips do you have? 10kw-15kw.. ect.
If you had heat strips previously, then i will just need to know the size and application.
Dec 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC042 Air Conditioner Logo
794 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
