Question about Jenn-Air JMC7000 Microwave Oven
GE less than 2 year old microwave runs, doesn't heat
Two days ago our GE JES 1142 WD 04 microwave stopped heating. The clock works, it runs, the lights go on, etc. There just isn't any heat.
  • 140 Answers
The problem you are having is that the magnetron that actually does the heating has gone bad. The fact that everthing works fine rules out any type of bad fuse since there is only one 15amp ceramic fuse in most cases in the unit itself. The magnetron is located behind the control panel on top and has some cooling fins on it. Replacing it if you are a do-it-yourselfer is pretty easy provided you can find one at local electronic supplier or on the internet such as if you would like to see what it looks like. It is held in place with typically 4 screws. It has two to three terminals depending on make and model and age. With everything unplugged it comes off easily enough with no desoldering or soldering to do. There is a High Voltage Capacitor and Diode that could be bad also, but without being able to check it in person it would be difficult for me to tell that they are. In my experience the magnetron is the first thing I replace and have never replaced a capacitor or high voltage diode in the past 20 years. Good luck and God bless.
Posted on Jan 23, 2009
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
Does not heat everything else works ge microwave oven JNM1851SMSS
It will be one of three things, magnetron, "heats food" high voltage diode,"sometimes cracks" or the high voltage capacitor, "usually shorts"
Mar 23, 2012 | General Electric JNM1851 1100 Watts...
Heats up barely 2 oz water lukewarm in 60 seconds. JE1140/JES 1142 microwave. HV Diode appears open. Should it look open one way and conduct the other as a normal silicon diode on a meter ? Magnetron...
Probably bad magnetron, GE uses the worse mags OM75P is Junk. They go out frequently. And they charge a LOT for them. Find a place called Global MicroParts. They are in Texas. They may sell wholesale only, Im not sure. But their parts work great and last.
Aug 18, 2017 | GE JE1140 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE zmc1095 microwave beeps and indicates "HOT" in the display
If it stops heating it needs a new magnetron. our oven is less than 2 years old and has gone thru 2 magnetrons so far. Hoping to get some help from GE.
Jan 28, 2009 | GE JVM2050 Microwave Oven
Microwave runs but does not heat
could be door switches could be pcb could be mag, cap or hv transformer.. Its really just a guessing game but one of the above is defo the cause best to get a tech in to have a look or get it replaced whichevers best for yourself
Nov 02, 2008 | GE JVM1650 1000 Watts Microwave Oven
My spacemaker GE 1440 do not heat it 2 years old
Hi tony,
The units magnetron(the device that generates the micro waves) is failed or failing, this can be DIY depending on how mechanically inclined you are.
Oct 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New wes1450dm1bbmicro purchased 2 wks ago worked fine now all controls work but does not heat
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | GE Microwave Ovens
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it:
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
334 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
