Question about Kenmore Elite Oasis 27052 Top Load Washer
Coin stuck in drain of elite oasis - Kenmore Elite Oasis 27052 Top Load Washer
  • 7 Answers
SOURCE: my kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Posted on Feb 04, 2009
dragonsthatk
  • 547 Answers
SOURCE: coin under the kenmore elite oasis agitator, how do i remove it
remove cap at top of cone unscrew
Posted on Feb 12, 2009
SOURCE: Oasis HE elite washer Sounds like coins
there are coins or small items in the pump. We used a wet dry vacumn to clean it out thru the drain hose.
Posted on Oct 25, 2009
jsrock516
  • 5911 Answers
SOURCE: I have coins under my tub in my kenmore elite
DO NOT attempt to turn this washer upside down! The wash tub is suspended by suspension springs and it will dislodge the wash tub from its mounts. The washer also weighs about 200 lbs. Not a bright suggestion.
In addition, if this is an OASIS, no special tools are required to remove the wash tub. It usually involves removing the center cap from the wash plate and loosen the bolt underneath with a socket. You will need to remove the wash tub ring in order to get the wash tub out, however. This is the pastic ring around the top of the wash tub. It simply snaps in place and can be removed by popping the retaining taps free with a screwdriver.
If you hear a rattling noise, I would recommend you check the drain pump first as "titelines" suggested. It is common for items to get lodged in the piump impeller and make noise. Keep in mind...there are TWO pumps on an Oasis. One is a recirc pump. Check them both. If anything has been left in the pump for any significant period of time, it can damage them.
You will need to access them both with the rear panel removed and the wash tilted up so you can access the mounting bolts and screws from underneath. I would STRONGLY recommend you drain all residual water from the wash tub prior to disconnecting any drain hoses. If you own a wet/dry shop vac, this can be accomplished by removing the drain hose from the standpipe and pulling a vacuum on it. This will minimize any mess you may have to clean up later.
If your model number differs from the one you posted this question under, please post back with your correct information. I hope this helps you.
Posted on Nov 30, 2009
  • 401 Answers
SOURCE: coins are in the drum of the washer how do I
It needs disassembled and requires special tools.
Posted on Jan 02, 2010
Clicking noises on spin
You have coins in your drain pipe and pump!
Mar 31, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I can't get the water to drain out of my washer. It had a code that read LD when it broke any ideas
Most of the time I find coins or socks jammed in the drain pump. Turn machine 180 degrees, tilt up against wall, and pull pump. Dislodge whatever's lodged in it.
Oct 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Makes a rattling noise inside like coins are stuck in it. Does this on the last spin cycle. Never find any money inside the drum though?
Having some trouble using this webiste. I have the exact same problem with my Kenmore Oasis top-load washer. Were you able to find a solution?
Dec 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis HE elite washer Sounds like coins rattling occasionally during spin cycle.
Oct 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My washer has an error code ld and it wont start or turn off i have to unplug it to turn it off now its stuck on on how do i fix it
"ld" stands for long drain. check the water pump for any obstructed items like coins, hair pins or clothing. the water pump is located in the bottom of machine in right back of stator. remove hoses and clean. also check the air dome located in bottom of basket.
May 05, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
