Question about Home Security
Learn button on Genie Pro 83 1/3 hp screw- drive
Where is the learn button located?
2 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: own late model 12hp Genie
It will be on the outer surface of the motor head, or under the light cover. It will be the only one you can press. Some older units have dip switches which look like a row of toggle switches. If so there will be no learn button. Thanks BB
Posted on Nov 06, 2010
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
How do I program a "clicker" brand remote for a genie pro 83 garage door opener?
generally you find the program button on the motor housing, press it once and it should start blinking, then press the remote button, and then press the remote button again and see if it works.
Jul 10, 2015 | Genie Pro Building Materials
Learn button for model GXL9500 where is the Learn Button located?
That is a Genie Opener and there are several "versions" of that. Take off the light globe that faces the door. Two screws at the top should allow it to fall and hang from the bottom attachment. Locate where the wires for the eye beams and the wall button are attached to the opener. The learn button should be right under those wires. Good luck!
Jan 19, 2015 | Building Materials
Can only open my garage door if i`m 5 feet in front of it. started doing this shortly after at@t installed a uverse box in my front yard.
This is most likely caused by radio interference. Try to re-learn the remotes to see if it will correct the problem.
Oct 01, 2014 | Genie Garage Door Opener 2562-TC 1/2 HP AC...
Where is the learn code button for genie GCG350ML garage door opener
Not an answer per-se but an endorsement of Don Maggard's answer for the 2015 rdx with a genie. This is the only process that has worked for me. The process in the car's manual was flawed. Thank you, Don.
Jul 29, 2012 | Home Security
Need to change the PROGRAMMING. Need new code set-up. thank you.I have no manual.
  1. Gently press the Receiver Learn Code button on the power head receiver of your door operator. This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. **
  2. After pressing the Learn Code Button once, press your transmitter button three times for your system to grab the frequency and code it in. (Keep the transmitter you want tuned at least 2 feet away from the power head while tuning.)
  3. Press the transmitter button once more to test the system and start your door moving.
**To erase all Intellicode remotes and wireless keyless entry, hold down on the learn button until the indicator light stops blinking, then proceed to Step 2.
Jul 09, 2011 | Genie Company Genie Intellicode...
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
Own late model 12hp Genie screw drive garage door opener and want to know where to locate the Learn Code Button.
Oct 22, 2010 | Genie Company Genie 33944A Excelerator and...
Programming my keyless entry
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
Nov 09, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Genie excelerator/
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote
Here is a copy of your manual
www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
Oct 12, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Home Security Logo
336 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
