If I try to make a call, hit talk,and the phone will blink 'connecting' , then stop and read 'unavailable' . I should point out this is only headset 2 with this problem. It's a Uniden 2.4GHz. Is there a way to get the second handset back to normal? I'm using Vonage and have a wireless router recently installed (with Comcast high speed broadband).
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
