Question about Kenmore 19365 Computerized Sewing Machine
Stitch is very loppy underneath fabric
Im not sure what the tension should be for a Janome RX 18S sewing machine can you please help with this. I used the machine yesterday and it was fine but today its very lopping
    Scholar:
  • 34 Answers
Hi, you shouldn't need to change the tension on your machine. But it's always a good idea to make sure it is set correctly. Look in your manual for the recommended tension setting, and make sure that is where your tension is set. If you don't have a manual, the default tension setting for most machines is between 4 and 6.
If you are suddenly getting loops when you sew your seams, it is usually caused by one of three simple problems. The most common is that your machine is not threaded properly.
But, when your sewing machine suddenly goes "wonky" - try these step
  1. Raise your presser foot and rethread your machine. Always remember to raise the presser foot when you thread your machine! When you raise your presser foot, the tension dials are released; when you lower the presser foot, the tension dials close around your thread. If you happened to leave your presser foot up when you finished sewing yesterday, the thread could have slipped out of the tension dials, so when you started sewing today, you got loops. And, sometimes, your sewing thread can shift out of position along the thread path and you can't see it. Trust me on this - I often need to rethread while I'm sewing, and I have an expensive machine! If your machine is new to you, it is always a good idea to refer to your manual the first few times you thread up - it is really easy to miss little things, even for advanced sewers.
  2. If you are still getting loops after rethreading your machine, remove your bobbin and reinsert it. Make sure you know which way your bobbin need to be inserted. After you re-insert your bobbin, sew another sample seam. If you are still getting loops...rewind your bobbin (you can put your bobbin where you normally put your sewing thread and wind the bobbin thread onto a new bobbin). Never wind more than one color on a single bobbin. When you look at the thread in the bobbin, it should be straight a tight. Yesterday, I wound a bobbin, and the thread was kind of wavy and loose. Don't know why, but it happens.
  3. Change your needle.
  4. Check your manual - most manuals have troubleshooting tips in the last chapter. If you don't have a manual for your machine, search on google. You might be able to find one online.
  5. If your machine is new, try calling the manufacturer or check their web site. They might have troubleshooting techniques specific to your machine.
If this doesn't help, please write again and describe your problem in more detail. Did you buy a used machine? Do you have your manual? Did you start a new project or continue working on the project you started when the machine was working correctly? Hope this helps! Ginny
Posted on Jan 31, 2009
I can't get the tension right on my Janome DKS30 sewing machine. I can operate a machine but I am quite a novice. My machine is 9 months old and I have used it less than 20 times. Can you please help?
Sounds like your top tension is too tight. You may find it helpful to join a FaceBook sewing machines group to get further help. Happy Sewing!
Dec 30, 2016 | Janome Sewing Machines
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
Jun 05, 2012 | Sewing Machines
Im using a free mashine foot to do embordery work and i cant get the tension setting right. ive tried all the diffrent settings and the stitch seems really loose when i sow. how do i get the setting...
First make sure you have a good quality cotton thread. I like to use Mettler silk finish 50 weight natural color. Start by sewing a straight stitch on two layers of light cotton fabric. You should have a tension the looks the same on both sides of the fabric when you sew. Adjust the tensions, if nessesary, and then try a sample on a practice sandwich. You might have to increase the top tension just slightly.
Apr 24, 2011 | Janome 4623 Mechanical Sewing Machine
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
Stitches are looping on the underneath and missing some stitches
Refer to the manual for cleaning.
Replace the needle with the size recommended for the type of fabric being sewn. The flat side of the needle is usually facing the back of the machine - check manual to be sure.
Always thread any sewing machine with the presser foot up. This opens the tension control so the thread can properly enter this device.
When a sewing machine is threaded with the foot down, the tension control closes and the thread cannot enter as it should
You then get loose stitches because the top thread and bobbin thread cannot make a proper stitch and the tension of the bobbin thread is pulling the top thread to the underside of the fabric.
Mar 07, 2010 | Janome Sewing Machines
Skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
Lost manual
I couldn't find my manual for the Dual Sew 3500, either, and long story short, I discovered the manufacturer of Dual Sew is the parent company of Janome; that the Janome 4618 Limited Edition is virtually the same machine; wrote to Janome and they emailed me the PDF manual for th 4618LE. What a relief.
Apr 20, 2008 | Dual Sew 3500 Mechanical Sewing Machine
Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Mar 25, 2008 | Bernina Activa 130
Kenmore 19365 Computerized Sewing Machine Logo
311 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
