Question about Toshiba 46G310U LCD TV
Toshiba 46G310U randomly turns off then back on
The television completely turns off... no green power light. it will stay off for a minute or two then turn back on. This could happen 5-10 times in an hour, or not at all in 3 hours. Very random, very annoying.
  • Jimmy Lam Nov 21, 2014
    I Have the same problem with set. The board is over heated and shuts down..
    Cold solder joints. Reheat the joints might fix it.
    New Friend:
Finally figured out the issue with this. It's a momentary dip in voltage caused by the A/C, dryer or fridge coming on.
I can reproduce this everytime by turning everything on, then starting the clothes dryer.
Posted on Jul 24, 2014
    President:
  • Toshiba Master
  • 749 Answers
You most likely have a bad power supply board.
The Toshiba number for this board is 75024143 and it is somewhat hard to find/expensive.
It suffers from a design flaw for a number of Toshiba boards from this time frame.
You can find repair services for many of them at our site www.coppelltvrepair.com and here is the listing for 75024143 in particular:
http://www.coppelltvrepair.com/p/984/repair-your-toshina-46g310u-power-supply-board-pk101v2520i-n249a001l-n272r001l-75024143
I would say that probably all boards in circulation out there will develop these symptoms over time.
Hope we can help!
Posted on Oct 17, 2014
  • 668 Answers
SOURCE: Toshiba LCD TV AV500E Turns off then on every 5 minutes
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
Posted on Jun 20, 2009
VinayT
  • 1884 Answers
SOURCE: Toshiba 50HP16 Plasma tv has
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
  • 541 Answers
SOURCE: Flashing yellow light on power button
It sounds like the seine board. I replaced several of these. Exteded warranty would be nice in this situation. Hope you have one.
Posted on Oct 13, 2009
vinnyq
  • 157 Answers
SOURCE: Toshiba Regza 40XV645U garbled sound
There is an issue with the audio processor. Most likely it is the main board needs to be replaced in order to fix the issue. You will need to remove the back cover in order to get access to it.
There could also be an issue with the power supply supplying the right voltage to the processor. This can be checked by seeing if the 18V DC is present at pins 3 and 4 of CN90 on the power supply. If the voltage is present, then replace the main board. If it is not, replace the power supply.
Posted on Nov 09, 2009
ripleymojica
  • 643 Answers
SOURCE: Sometimes the power turns off
unplug unit for 3-4 hrs. if that doesnt help you may have a bad powersupply.
Posted on Mar 21, 2011
Hi i purchased a 32 in. lcd tv on black friday and know i went to turn it on and it flashed and know the red and green light stay on when u power it on
Disconnect the power completely. Wait 15 minutes. Plug back in. Turn on. If it doesn't clear, use your warranty.
Jun 16, 2011 | Emerson Televison & Video
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Viewsonic model vs10846-1m aka N4060W won't turn on.
I found if you hold the power button down on the remote or the tv , hold it down for anywhere from 2-5 minutes the green light will blink and blink and blink, all of the sudden it will stay on. then shut off, but if you turn it back on on the light will again stay on , do this 3-4 times and then the tv will turn on. Once you turn it off for over 10 minutes you will have to go through the whole rigamaroo again. This will only work for a while, mine has quit completely now. The Veiwsonic guy gave me a part number for a power board he said was most liley the issue. It ran about $71. I've got a repairman coming tomorrow to see what the dealio is. I'll let you know what he tells me, good luck!
Jan 28, 2009 | Televison & Video
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Maxent 50" plasma problem
We seem to have had the same problem. Green light keeps blinking but will not turn set on or off. I unplugged the set for a few minutes, plugged back in and works fine but will happen from time to time for no reason.
Sep 12, 2007 | Maxent MX-50X1 50 in. Plasma Television
Toshiba 46G310U LCD TV Logo
1,407 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
