Question about Samsung LN52A630 LCD TV
Samsung ln52a630 turns off on
Turns off and on
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Model LN52A630. Why won't it turn on?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 30, 2015 | Samsung Televison & Video
I have a 5 yo 52" Samsung lcd.From a cold start it cycles on then off about 6 times before a picture comes on.I replaced capicitors and no difference. Whats next?
Most of the time only secondary large electrolytic capacitors are being renewed althoug small E. capacitors in a primary circuit of an smps (around the switching driver IC) can also cause this kind of issue. Although you say you replaced them i still believen its a bad capacitor.
Jan 29, 2015 | Samsung LN52A630 52-Inch 1080p 120 Hz LCD...
How do i enter the nuc code on a samsung wave mobile phone
Samsung SGH-a300
*2767*637#
Samsung SGH-a400
*2767*637#
Samsung SGH-a800
*2767*637#
Samsung SGH-e400
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e500
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e700
*2767*688#
In newer phones:
#*7337#
Samsung SGH-E715
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000.
In newer phones:
#*7337#
Samsung SGH-m100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Samsung SGH-P400
*2767*3855# or *2767*688# or *2767*927#
In newer Samsung models:
#*7337#
Samsung SGH-s100
*2767*7822573738#
Samsung SGH-s105
Remove SIM Card. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Samsung SGH-s300
*2767*7822573738#
Samsung SGH-s307
In newer phones:
#*7337#
Samsung SGH-S500
In newer phones[/color]:
#*7337#
Samsung SGH-600
*2767*3855# or *2767*2878#
Samsung SGH-2100
Samsung SGH-V200
*2767*7822573738#
Samsung SGH-X100
In newer phones:
#*7337#
Samsung SGH-X600
In newer phones:
#*7337#
Samsung SGH-R210
*2767*3855#
*2767*2878#
Samsung SGH-D500
#*7337#
Samsung Universal Type
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
May 30, 2010 | Samsung Lands Phones
I have a color stripe from the top to bottom on the right center.
It is panel related problem if you can open LCD than open & clean all connector properly & refit properly.
Jan 23, 2010 | Samsung LN52A630 LCD TV
I have a black line going across my 52' samsung lcd tv.
If you can see this line with the unit off you have what is called delamanation.The only fix for this is panel replacement.This is a common problem with Samsung LCD panels.
Jan 12, 2009 | Samsung LN52A630 LCD TV
Refresh rate at 60 Hz?
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010100&model_name=LN52A630M1F
According to the Samsung website, the on-screen information is in relation to the incoming signal, not the TV settings which are being displayed.
As long as you have the 120 Hz turned on, the TV will display the picture at that refresh rate. However, the on-screen information will not reflect that.
Very ood.
Dec 19, 2008 | Samsung LN52A630 LCD TV
Hi. I bought a new Samsung LCD Flat Panel TV, model LN52A630. I started playing with different settings and completely messed up, and i cannot set it back. Is there an option that i can use that resets all...
Most TVs have both a consumer menu system and a service menu system. Assuming you stayed in the consumer menus, there maybe a reset or defaults selection. Look around. If you don't find it, use google to locate a downloadable manual for your specific model. An occasional TV resets to default settings if you unplug it for 48 hours. Many have resets in the set menu when you program channels, parental control and time.
Dec 12, 2008 | Televison & Video
Samsung LN52A630 LCD TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
