Question about HP Photosmart C7280 Printer
"Missing or Damaged" cart message.
Our C7280 displays a 'Missing or Damaged Cartridge' message as soon as it is turned on, but does not list any colours to replace.  We have removed and replaced all of the colours (all brand new) to no avail.  The carts printed fine a few days ago but now the printer won't even let us select a different mode - we can't send a fax, scan or anything.
  • nimmi68 Jan 26, 2009
    I'm having the same problem & called the hp technical support. My warranty expired only 16 days ago & the agent said is a hardware problem & offered an upgrade printer or the same printer for a 45% discount but the prince quated $220 was $60 more than I paid for this printer a year ago!
    Scholar:
  • 169 Answers
You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the printer.if the problem again comes up try thesame with # and the number 9 buttons
see if it works,else get your printer serviced
Posted on Jun 25, 2009
Just purchased a used HP LaserJet 4 Plus -- when turned on and installed it is showing 14 no EP CART -- we do not use cartridges so need to reset to default settings. Tried Power On and holding online but...
Ensure that the Toner Cartridge is installed correctly (fully
seated into the printer). Try a new Toner Cartridge. If the
problem continues, try this
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 Reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller.
Jul 05, 2011 | Office Equipment & Supplies
I inserted non-HP cartridges into my C7280 printer and the display says "the ink cartridges appear to be missing or damaged", If I put the original HP cartridges back in, the error message...
Turn off your printer
Open the cover
1 .move the cartridge carrrier manually to the center manually with your hands from left to rgiht ( 5x )
2 .Open the cartridge carrier Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean specially the gold plate .CLean also the area where you return your cartridges also the contacts on the cartridge carrier make sure its clean OK .
Then return it again
You may also do that when your printer is on
1 . Open the cover first wait for the carrier to move to the center
2.thats the time you will remove the cartridge and clean and clean the cartridge carrrier
3.open again the cover reinsert the cartridges
make sure its close properly
Hope it help ..
If still nothing happens probably you have a fake cartridge which is not recognized by the Hp printer Ill be advising you to return it back and asked for a replacement OK
May 28, 2011 | HP Photosmart C7280 Printer
Not sensing the ink cartridge
In this scenario you should check with a new set of black cart or you can try by cleaning the cart with a lint free cloth. and try with resetting the printer as well. if it doesnt work then printer might have gone bad
Oct 21, 2009 | HP Photosmart C6280 Printer
Color cartridge missing
You may want to remove the power brick at the back of your printer, wait a few seconds and reinsert back. Then try the steps listed in the user guide to install new carts, page 42.
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Jun 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error message: color cartridge missing on a Dell 922
try another cartridge. if that works then you have a bad ink cart, if not, the sensor is bad, replace the printer.
Dec 30, 2008 | Dell 922 All-In-One InkJet Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
HP Photosmart C7280 Printer Logo
123 people viewed this question
Seeker5211
Seeker5211
