Question about iLive Is809b Speaker System Is809b
How do you fix a ilive when it wouldn't play for the tv
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
How to connect ilive ITP180b sound bar to a 55"Emerson?
http://www.manualslib.com/manual/257417/Ilive-Itp280b.html
Sep 29, 2014 | iLive New Itp180b Ipod/iphone Soundbar
My ilive itp180b sound bar won't play sound from my lg plasma tv
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 02, 2012 | LG Televison & Video
When i plug my iphone 3gs into the ilive itp100b i try to play my pandora music app and the music plays for 2 seconds and then stops. the music on the app continues to play on the phone but the ilive isnt...
I have this exact same problem... audio I loaded on through itunes play perfectly... songs, audiobooks, podcasts, etc, as well as input from my TV and the build in FM radio, but anytime you try to use any 3rd party radio app on the iphone, you get like 2 seconds of audio and then nothing, and the app usually has some text that says, "No Volume Available".
From research, it seems that the iLive company is to blame as they did not update the firmware to work correctly with iOS 4, so it is their problem and not the iPhone. I am returning my device and getting another brand that supports iOS 4
Dec 21, 2010 | Audio Players & Recorders
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
My ilive speaker bar IT188B will not play through my television...what do I do?
Make sure that your audio in on Ilive unit is going to your tv's audio out. Your tv may have a setup to able the audio out. Refer to your tv's owner's manual. I have to do this on my tv to my Ilve unit.
Dec 27, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
User Manual
here it is for u but i need u to rate me as fixe ya hehe the blue 4 squares!!
http://www.ilive.net/store/p/44-CD-Boom-Box-with-Subwoofer-Dock-for-iPod-.aspx
Aug 17, 2008 | Apple iLive IBCD3816DT Portable 2.1...
iLive Is809b Speaker System Is809b Logo
19 people viewed this question
Top iLive Home Security Experts
Lawrence Oravetz
Are you an iLive Home Security Expert? Answer questions, earn points and help others
