Question about Dryers
GE PROFILE DRYER #212D1630P108
DRYER will not shut off automatically.
localwonder
  • 6784 Answers
SOURCE: I have a GE Profile dryer. The dryer is squeekly
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Concerning the squeaking sounds. this can be caused by a bad drum belt or a leveling issue as well. more issues will be bad drum support rollers or, a failing bearing assembly in the idler pulley. the blower, baffles and guides will deteriorate as well, causing noise overtime. These are most of the uncommon issue that will cause this issue, but the most common issue will be failed idler pulley bearings. The pulley will tend to squeak very loudly if the bearings are worn.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Jul 30, 2009
garing
  • 998 Answers
SOURCE: DescrI have a GE profile harmony electric dryer
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Posted on Aug 07, 2009
  • 1531 Answers
SOURCE: Dryer wont shut off
then you may need to replace moisture sensor bar located inside the drum area usually on the front or rear of the drum area they are two silver bars
Posted on Sep 27, 2009
milten1
  • 1304 Answers
SOURCE: GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Posted on Oct 15, 2009
Testimonial: "Fast and Courteous Feedback!!! Thanks again!!"
ftw1952
  • 10319 Answers
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
Posted on Mar 12, 2010
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
look in the
230
Oct 15, 2009 | Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
I have a GE Profile refrigerator the does not produce ice cubes
the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
DRYER PROBLEM
my dryer shut off one day and will not start up I reset the breaker switch and no luck
Oct 06, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
78 people viewed this question
Top Dryers Experts
