Toner alarm stays on with new cartridge
I have an older Okifax 2350 that had been stored for a few years. Plugged it back in...and it sends faxes fine. The alarm light came on, the LCD shows ''toner low''...I buy a new cartridge, install it, and the alarm light won't turn off, the toner won't feed and it will not print a page. The user's manual suggests to change the drum, the MCNT board etc... geesh. Is there something specific I should be looking for? I ran the print cleaner utility several times without success... I need ideas!
  • 62 Answers
Printhead is dried up and may need to be replaced. The printhead usually has a life kinda like the inks. You should be able to find a printhead from your local fax repair shop and installation should be simple. Once replaced you may install inks and run several cleaning cycles. Please let me know if this helped.
Posted on Feb 14, 2009
I have an Okifax 2350. It sends faxes fine but won't print. The screen says "Paper Jam" and "Replace Paper." I am fairly certain there is NO paper jammed anywhere in the machine. ...
Yes, it could be a sensor. Remove the toner and drum assys as well as the paper cassette and look for the sensor actuators. Usually black plastic pieces that will move a bit. Blow them out with air and see if that doesn't help. Let me know.
Jan 09, 2011 | Office Equipment & Supplies
How do you change a toner cartridge
Open up front op panel,mid door opens up tube sitting on top of drum unit is the toner cart! be care full can get messy!Pull lever on end of tube (will only go 1 way from original position)lift up and dispose of.pull white tape off of new cart install in drum push lever,open and close mid door a couple of times to cycle toner toner message will disappear.
Nov 23, 2010 | OKIFAX 4580 Plain Paper LED Fax
Have a Okifax 5400 - changed toner and drum but still getting blank line down side of the page. Any way to fix?
clean the LED array with a soft cloth or tissue or the alcohol wipe that comes with new toner cartridges if you still have it. open the cover to expose the drum on the bottom side of cover is a black bar(LED ARRAY) as wide as the drum but about a half inch thick wipe the bottom side that will face the drum when the cover is closed
May 21, 2010 | Office Equipment & Supplies
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
Check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
May 13, 2008 | OKIFAX 5650 Plain Paper LED Fax
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
136 people viewed this question
k24674
jasbo
jasbo
