Question about Whirlpool Dryers
Whirlpool Ultimate Care II LEQ8000JQ4 no heat in dryer
Hi! No heat, but sounds like it works fine. Is it a heating element and how much do these generally cost? I'm pretty handy for a chick...
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
Posted on May 25, 2008
SOURCE: Gas dryer heats up but then cools down within minutes...HELP
blocked vent
Posted on Feb 17, 2009
  • 29 Answers
SOURCE: We have a Whirlpool Ultimate Care II gas Dryer
Could just be a matter of wires coming loose. The movement and vibration of the spinning could have shaken wires loose. look for any wires not connected to anything.
Posted on Nov 06, 2009
  • 249 Answers
SOURCE: my Whirlpool Ultimate Care II dryer does not heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 02, 2010
Dryer is not heating
check fuse box first to see if one 1side of the breakers have tripped if this is not the case then the element burned out and needs to be replaced
Feb 10, 2010 | Whirlpool Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
Jan 02, 2010 | Whirlpool Dryers
Replaced bad heating element but the heating unit is still not working. There are two sensors located on the heating compartment. Could one of these be bad. Whirlpool Dryer Ultimate Care II
yes they could be defective check with multi meter and replace the one with no continuity sound from meter,no bleeping, make sure power is off
Jun 23, 2009 | Dryers
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate ii electric dryer stopped heating
change out the heat element, you can get the part at Sear
Nov 27, 2008 | LG DLG2524 Gas Dryer
Ultimate care II Whirlpool dryer
May 24, 2008 | Dryers
Whirlpool super cap. electric dryer imperial
element or thermal fuse at top of element housing most likely if either is bad ck vent system before using very long plugged vent can cause overheat long dry times and premature failure of element
Apr 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
