FixYa.com
Tags:
Pantech C300 Cellular Phone
BACKLIGHT STILL ON (by 2 users)
posted by BIGMAMA1600 on Jul 08, 2007
MY CELL PHONE GOT WET. I USED A BLOW DRYER AND PLACED IN A BOWL OF RICE FOR A FEW HOURS. THE PHONE WORKS BUT THE BACKLIGHT IS STAYS ON WHERE THE FLIP IS OPEN OR CLOSED. HOW CAN I MAKE THE BACKLIGHT GOT OFF (IF THAT IS POSSIBLE)?
Comment by BIGMAMA1600, posted on Jul 10, 2007
Your answer seems very helpful but there is one other problem. I was trying to disassemble the phone but the screwheads are so small I do not have a screwdriver small enough to fit the head. I tried using the screwdriver that comes with an eyeglass repair kit nd even that was not small enough. Where can i find a screwdriver that could fit the heads of the very small screws in this C300?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 08, 2008
my blacklight is also still on, it was in a cup of water for about three seconds and dried out overnight.
Best Solution
posted on Jul 08, 2007
Helpful (85)
Priority1
Rank:Wiz Wiz
Rating: 84%, 248 votes
How wet did it get? Was it submerged?
The backlight would normally shut off after a short idle period or when you close the cover. If it is staying on all the time after water damage then there is still water in a component (like a capacitor) or corrosion that has opened or shorted a circuit path somewhere confusing the phone. There is a good chance that corrosion will become worse and do more damage. New problems could arise any time in the next few days or few years.
If this were my phone I would disassemble it and clean it with rubbing alcohol, toothbrush, and air duster but there is some risk even for someone experienced. Also, microphones can be damaged by fluids including rubbing alcohol.
Comment by Priority1, posted on Jul 10, 2007
I am not sure what tool is required as I do not have any information on your specific phone. I'd try Radio Shack for the tools. However, I would think they did not use tiny old style, flat-head screws. Usually you would see either small phillips head or star bits. If it's a star bit. Husky makes an inexpensive, small star bit assortment kit. The type that looks like a single small screwdriver and the handle comes off with multiple bits inside. I've seen that at Radio Shack and at Home Depot. Come to think of it, they also make the same thing with an assortment of small flat-head and phillips head bits.
Rating Locked! (?) BIGMAMA1600 has rated this solution as Helpful
Can you Help with these Cellular Phones problems?
GPRS SETTINGS
how can i activate my gprs... Answer This...
Stopped sending picture...
After months of sending 2-3... Answer This...
usb data cable
I just bought a usb data cable... Answer This...
Display on Pantech C-300 does...
It is back lit but no display... Answer This...
envelope symbol with an...
Lately, I have received some... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
