Question about Saab 9-5 charge air bypass valve. supercharging system, vacuum system
What is cel code p1110 - Saab 9-5 charge air bypass valve. supercharging system, vacuum system
I have a saab 93 2002 with engine codes,p1110,p1312 and p1334 showing can anyone please tell me what they mean!
CODES P1312 AND P1334 These codes are related to the DI Module. Check the DI Module. Replace it if needed and clear the codes.
CODES P1110 Code P1110 is related to the Turbo Bypass Valve, check the vacuum lines at the Bypass Valve and especially at a vacuum sensor mounted on the firewall driver's side. The lines become loose with age and will pop off or can become disconnected when someone is reaching behind the for other reasons.
Jun 03, 2015 | 2005 Saab 9-3 2.0
What is code p1110
Dear Anon,
Could be, P1110 is Charge Air Bypass Problems. I would check all the pipework (small bore vac pipes) to and from the dump valve, plus if you have one of those plastic bosch valves it might be time to change it. If you trace the small bore tube from the dump valve back to the bulkhead. Remove the tube, clean the end of it then suck/blow (i can't remember which one), if you can suck/blow the diaphragm has gone in the dump valve and it needs replacing. As Chris already said, check all the vacuum tubing as well for splits/tears and whether they are actually attached. Thanksto Kermit/Chris9-5
Sep 15, 2014 | Saab Vehicle Parts & Accessories
Error code P1110
Without the vehicle make you will not get the correct response, however the genric meaning of this code is:
IAT Sensor (D/C) Open/Short
OBD2 Check Engine Fault Codes Android Apps on Google Play
Mar 07, 2014 | Cars & Trucks
Fault code p1110
P1110 Intake Valve Timing Control Circuit (Bank 1)
Sep 10, 2013 | 1996 Nissan Sentra
Trouble code P1111 intake valve timing control circuit malfunction Bank 1.
P1111 is intake air temperature, which has nothing to do with intake variable valve timing. If the code is P1110 then yes you have a intake variable valve timing but before you throw a solenoid in the mix make sure you are properly changing oil on time and do do have low oil level you basically have poor oil maintance for P1110 to take placecansmo_161.gifcansmo_162.gif
Aug 29, 2011 | Nissan Murano Cars & Trucks
Emission trouble code p1110
P1110 means problem with a turbocharger bypass valve.Check the first all hoses if OK change the valve.
May 04, 2011 | 2001 Saab 9-3
Screen resolution problem with hp p1110
Right click on the desktop and select Properties->Settings. Change the resolution here to what you feel is pleasant and wanted.
Nov 16, 2009 | HP P1110 21" CRT Monitor
Trouble shooting code
This code indicates a problem with the variable valve timing control, or the sensor for camshaft position, most likely it is the cam sensor
Jan 27, 2009 | 1998 Nissan Sentra
P1110 Blurry/dubble image
your beam needs calibration take it 2 a pro... windman
Jan 28, 2006 | Dell UltraScan P1110 21" CRT Monitor
Saab 9-5 charge air bypass valve. supercharging system, vacuum system Logo
Top Saab Heating & Cooling Experts
ray gallant
Jerry Kramer
Jerry Kramer
Lawrence Oravetz
Are you a Saab Heating and Cooling Expert? Answer questions, earn points and help others
