Question about Toro Garden
High altitude enginge operation/toro powervac adjust the enginge to run above 2000 feet
hotuna
  • 288 Answers
SOURCE: High Altitude Electric Heaters
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Posted on Dec 26, 2007
kel1guy2002
  • 3740 Answers
SOURCE: Getting error code 13 when heater runs 2-3
Hi and welcome to FixYa, I am Kelly
The error code 13 from memory is indicating a venting / flame / improper combustion problem. I recall seeing a C7 or a C4 before an error 13 though.
There is one sensor called the Oxygen depletion sensor and the code 13 appears for this sensor when it is sensing poor or incomplete combustion
Oxygen Depletion Sensor
(Poor or Improper
Combustion)
I honesly am not certain but I think it is item 4 of the parts list below (Flame rod) PN: RTG20164H
^- I believe this is the sensor causing your problem This is a stand alone sensor.
Your other 4 sensors.
PN: RTG20164P (Yellow) Heat exchanger Thermisor
PN: RTG20164R (Blue) Ambient Air Thermistor
PN: RT20006AR (White) Inlet Thermistor / water line
PN: RTG2006BB (Black) Outlet thermistor / water line
The inlet and outlet thermistors will have the same resistance Pair 1
The heat exchanger and Ambient Air thermistors will have the same resistance. Pair 2
It is best to check these when the unit is at Ambient air temp as the resistance values will be the same. If you note any major resistance differences or opens..between each of the thermistor pairs, the thermistor is bad.
Your parts are in this link pages 14 - 16:
http://waterheatertimer.org/pdf/Rheem-TanklessParts-Accessories.pdf
These thermistors if they outright fail show up as error codes 29, 31, 33, 34 and 35 You could just have dirty / corroded thermistor terminal(s) connector(s) or minor corrosion on the main PCB.
Just make sure your repair efforts are directed toward the flame rod and associated wiring.
Thanks for choosing FixYa,
Kelly
Posted on Jun 25, 2011
bonedivers
  • 1140 Answers
SOURCE: have a customer with a 2006 fjr1300, at high
could be either one
Posted on Jul 10, 2011
  • 63 Answers
SOURCE: 2003 camry high altitude adjustments
your vehicle is equipped with a m.a.p. sensor or a mass air flow sensor. the p.c.m. will make the necessary calibrated adjustments. back in the carburator days you would need to jet the carb- but those days are over. hope this helps
Posted on Aug 30, 2012
yosemyt
  • 322 Answers
SOURCE: What is the high altitude adjustment required by the manual?
the high speed adjustment needs to be richened up to compensate for the lean air mixture at high altitude. it can run but will run fast and may damage the unit because it is lean. the high speed adjustment is the one marked H or the screw farthest from the engine. turn it counter clockwise while running at full speed until it runs at the correct RPM. any small engine repair center should be able to do this for you and keep you from causing irreparable damage
Posted on Mar 02, 2013
High altitude operation of a ryi2200 generator (5000 ft)
You require a high altitude carb (or carb jet) to operate correctly at this altitude. The jets are smaller to compensate for the thin air.
You need to get in touch with Ryobi to see if they sell them.
Do not adjust anything else on the generator!!!!
Dec 22, 2016 | Electrical Supplies
Does the altitude of 4000 feet has affect on someone with low blood pressure?
I am not a doctor but I can tell you that at 4000 feet there is about 87% of the oxygen compared to sea level. High altitude is usually defined as 5000-11,000 feet. High altitude actually increases the body's blood pressure.
Dec 10, 2016 | Health & Beauty
At high altitude polaris runs rough and lopes
well not knowing the model or year of mfg , ill assume its one with fuel injection , the mAP Sensor is the device that controls this function , they do sometimes get clogged up and require a good cleanout with some Map sensor spray (don't use brakeclean!!!) unless you want to buy a new one (sensor that is not atv) but even that's only gonna get you too about ten thousand feet , any higher than that your gonna need custom software to get it to run ok
Sep 29, 2016 | Polaris ATV
Feb 27, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
My yamaha yz 125 is dumping to much fuel and fouling out the plugs but i need to knoew how to adjust my carb its a 1997
There are only two adjustments to make on your carburetor; the idle speed, and the idle mixture adjustment. If the spark plug fouls frequently, first make sure you are using the correct spark plug. Your 1997 YZ125 uses an NGKB9EGV. Then be sure you are using the recommended two stroke oil, mixed to the proper ratio, in the fuel. Also make sure the air filter is not excessively soiled.
With all of the above confirmed and corrected, start the bike and run until the engine is up to normal temperature. Adjust the idle mixture screw to attain the fastest idle and best throttle response. Then adjust the idle speed.
If you are still fouling the spark plug, verify that the carburetor has the correct size jets by consulting your owner's manual. Keep in mind that if you are operating your bike at an altitude higher than about 6,000 feet above sea level, the stock jetting may be too rich. Down-size the main jet in small increments until satisfactory operation and the correct spark plug color is obtained.
Nov 02, 2009 | Yamaha YZ 125 Motorcycles
I have a new Husky saw that does not maintain accelleration. I'm operating at 7,500 feet above sea level. And apparently you need a special tool to adjust the carb? And there is nothing in the manual on...
All modern saws are set to operate very lean at sea level (thank the EPA). If you bought it locally take it back to your Husqvarna dealer, he should adjust it without charge. If purchased at a big box store or on line I'd take it to a dealer at the altitude where you use it and ask them to adjust it. there will be a fee but running it to lean will cause it to fail. A few dollars spent for an adjustment will certainly be less expensive than a new saw.
Lou
There are tabbed plastic caps on over your fuel adjustments. Thank the EPA once more.
Sep 04, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
22R Carb at high altitude
Yes, Colorado is much higher in altitude. Do to higher altitude the barometric pressure is less than sea level by a long shot. Lower barometric pressure mean that less air is entering your engine. Which in turns mean that your engine is now running richer than it was at a a lower altitude. So I recommend checking you engine timing, and adjusting your carbs air/fuel mixture. yes this means that you may need to rejet. but first there is a screw on your 22r's carb that you must adjust to lean the air mixture just right. I have had a stock 22r carbortor before and never had to rejet it. i probibly should have but it ran fine at sea level and all the way to about 10000 ft. after 10000 feet i had to lean the fuel mixture to even alow the engine to run. This screw that you must turn is hidden due to toyota not wanting you to tamper with it and burn your engine to the ground by running your engine to lean. it has a metal plug on the passenger side of the carb about the size of a pencil eraser. you must drill that out and then you can adjust the air fuel mixture. Clock wise is to lean the air fuel. and Counter clock wise is to richen the air fuel mixture.A good rule of thumb is to turn the air/fuel screw all the way clock wise and then back out about 2 and 1/2 turns. That is the factory adjustment. you may only need 2 turns out. Best of luck i hope you get it running perfect. Try this adjustment first then if it still runs rich then think about rejetting.
Here is a picture of what i am talking about.
#1 is the air/fuel mixture, #2 and #3 are cold and warm idle screws.
#4 is a A/c idle adjustment.
Sep 04, 2008 | 1987 Toyota Pickup
Dec 26, 2007 | Dayton Electric Heater
Garden Logo
61 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
