Question about Exercise & Fitness
Weslo cadence s6
My tredmill named above keeps tripping the power in my house, i have changed the amp in the plug but the same problem happens straight away.
is there another fuse i should be changing ar is it something else?
    Problem Solver:
  • 13 Answers
I would first try to plug it into another wall receptacle on another circuit in your house. If it trips out that (other breaker), I would check out how much draw (in amps) that the treadmill is drawing. Look at your user's manual and it will tell you how many amps that it should be drawing. That will tell you if it is the treadmill or other items in the circuits are causing the problem. You may have to many items on your circuits drawing to many amps for that breaker.
Posted on May 13, 2009
I need to download a manuel for a weslo cadence G 5.9 tredmill
User's Manuals Right-click on a view manual link and choose 'Save Target As...' or 'Save Link As...'.
If you are having trouble opening or viewing the manual, make sure you have the most recent version of Adobe Acrobat® Reader, which you can download here
WESLO CADENCE G 5.9 TREADMILL (WLTL29609) CANADIAN FRENCH MANUAL
View Manual in PDF Format ENGLISH MANUAL
View Manual in PDF Format SPANISH MANUAL
May 12, 2015 | Weslo Exercise & Fitness
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
Treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
May 17, 2010 | Weslo Cadence Ct 5.8 Treadmill
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
I have a weslo cadence tredmill practily new its been in a corner maybe a year went, to get on it no power please help if you can, thank Marsha Willis
check on/off switch located in frt of item where power cord goes in....and if that works, since its been just sitting there folded up, lubercation will be needed under walking belt-do not use silicone spray or wd-40. it has to be a special lube from manufacture-find manual,there is phone #, ask 4 parts dept, tell them u need lube of item, they and send with credit card let me know when u get, i will tell u how to apply lube, its easier then making coffee...david
Jan 06, 2010 | Weslo Cadence 60 SE Treadmill
I need manual for a Weslo Cadence SL 25 tredmill. I want to know where the fuse is. My treadmill sit in the garage for two years now it wont start, none of the lights come on. The only thing that works is...
Do a search with the following, icon health and fitness, click on customer service, then click on manuals and you should hopefully find it free there.
Jun 29, 2009 | Cadence Exercise & Fitness
Exercise & Fitness Logo
551 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
