Question about D-Link DCS-5220 Network Camera
D-Link DCS-5220 - Wireless connection constantly dropping
When I am watching the surveillance through by IE browser, the connection constantly drops, and after awhile it will automatically re-establish the connection to the camera and I can see the video image again. I am on Vista. And the camera is 10 meter from my wireless G-router, DIR-455, seperated by 2 wall. What could be the problem? wrong browser? Too far?
    Novelist:
  • 181 Answers
If you have configured Motion Detection then your problem may be because the camera only turns on when motion is detected. That is why it will seem as if the camera is dropping the connection.
If motion detection is not configured then you may be experiencing the same thing I have experienced. The camera does not record in full real time. It only gets snippets of information so the subject seems to jump from one place to another if they move fast. I guess this is a feature of IP cameras because they need to pass through the network with a lot of overheads. This is where good old CCTV cameras with their coaxial cables are best. They may be more difficult to install because of the cabling but their performance is a lot better
Posted on Jan 04, 2010
How to recover corrupted firmware for IP camera DCS-5220?
http://support.dlink.com/ProductInfo.aspx?m=DCS-5220
Go to this site and download the drivers
Then
Uninstall old drivers and install new ones
Jan 06, 2017 | D-Link DCS-5220 Network Camera
I have a d-link dir 600, it drops off all the time. Connected direct to internet, never have issues only with the router why
Try a factory reset.
Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Mar 07, 2012 | D-Link DIR-600 Router
Hello? how can i fix this code error 0x80004005 on splitcam?
May be a licence problem do a check using IE
> Tools > Internet Options > Advanced
Scroll down to Security and check the box = Allow the software to install or run if the license is invalid > OK
Restart computer and try your software using IE
Jul 24, 2010 | D-Link DCS-5220 Network Camera
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
Wireless keeps dropping constantly
try updating the firmware of the router.
Dont forget to vote fixya rating
Sep 13, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need to change the channel on my dlink 625 router..can u help?
I presume it's a cordless phone? If so, it's possible that it's interfering with the wireless signal. If that happens you will see the wireless connection being dropped - go into the wifi config utility and check how good the connection is. If this is the case, changing the channel may help. To do that,bring the router over to your PC and connect with an ethernet cable (just in case something goes wrong with the channel change and you lose the wireless signal.).
You need to find the "router homepage" in your web browser. If you don't know what it is, in windows click start -> run -> type "cmd" and press enter. In the command screen that pops up type "ipconfig" and press enter. It'll show you a few things. One should say "Default Gateway" followed by numbers.Write those numbers down (probably will be something like 192.168.1.254).
Open your web browser (IE, Firefox etc...) and enter the numbers. This will bring you to the router page. There should be an option like "Wireless" and under there you should see "change channel". It may be in the advanced option window.
IF your computer is NOT dropping the wireless signal when the phone rings, but the internet connection does drop - check the DSL signal light on your dlink. If it is flashing or not on, then the problem is with the DSL filters (small white connectors sent with your modem.). Always ensure any phone on the same line as the DSL is filtered or it will cause the internet connection to drop whenever the phone rings or is picked up.
Aug 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
Not Showing a Video output in Mozilla
I haven't got solution for my problem. but I have got the total specification of my D-Link DCS 5300G Web CAM from net and It's clear that My Web CAM not support any other browser except Internet Explorer. If I am wrong please tell me.
Sep 22, 2008 | D-Link DCS-5300G Network Camera
Wireless installation for DCS-5220
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Dropping Connection
This link indicates there may be an issue with hiding the SSID in the wireless router. A security item employed by some users. IF this is the case consider broadcasting the SSID and employing WEP or WPA encryption in the wireless configuration for both the router and the adapter cards to secure the wireless connections..
see
http://arstechnica.com/guides/askars/wifi-drop.ars
Dec 11, 2007 | Linksys Wireless-G WRT54GS Router...
D-Link DCS-5220 Network Camera Logo
1,223 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
