Question about Nintendo Wii Console
The Wii Controler Wrist Strap got ripped
I was playing Wii Bowling, and actually got into it. I think it is the best game in the console and it shows exactly the motion like I do it. The problem was that I got a little bit excited and I let go of the remote like it was a real ball... The strap broke and I hit the corner of my TV, luckily it did not hit the screen, my TV is fine and the control still works. I need to replace the strap, but I don't want to replace it by another strap from Nintendo I want a stronger one. Does anyone know where to get it?
  • Danzel boyd Jul 08, 2007
    Slyde great answer! I will look for it at walmart. Hopefull it is as durable as you said it is, because sometimes I am affraid I will break the house with this game...
    Thank you!!!
    Scholar:
  • 59 Answers
Go to any game store or anywhere that sells accessories for the wii (wal-mart) by a skin that comes with a strap they are usualy a little stronger looking, the skin will also prevent the remote from sliding out of you hand, i had the remote go flying while playing tenis once but i didnt have the wrist strap on, it bounced off the wall and came back to me and is still ok, they are pretty durable but the skin is the best way to go I wouold recommend a madcatz skin, they make the best recharge station right now and they are cheap and usualy a decent product.
Posted on Jul 08, 2007
SOURCE:
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Both wii remotes stopped woking..held red button in 4 15 seconds still not working
Well what we did we had the same problem I first put on the wrist strap i was afraid to do this but it worked act like you are bowling or slap it .
Feb 12, 2010 | Nintendo Wii Remote Controller
Wii remote problem
Hello. Make sure you have fresh batteries, double check for damage, and make sure you stay in LOS (line of sight). That means it's not like the PS3's bluetooth controller. You have to make sue the Wii's controler can "see" the sensor bar or you will have intermittent problems during game play. Thank you!!
Jan 17, 2009 | Nintendo Wii Console
Very slow
Silly me! I just changed the batteries in my wii remote.
Jul 19, 2008 | Nintendo Wii Console
Wii sprts bowling
All my friends have a bad habbit of doing this. Watch the instructional animation when it shows the instructions. This will help you. hold up wiimote hold B, keep holding B and swing back, then swing forward and release B button.
Dec 27, 2007 | Nintendo Wii Console
Wii Sports
Maybe the Nintendo Wii overheated because you played with it for too much. Give it a rest and go back to it later.
Dec 16, 2007 | Nintendo Wii Console
Wii bowling
This will only happen when you are a beginner.... Once you have played a few games it will go away. If you are playing as a guest the bar will always be there.
Nov 18, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
