Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn pour-omatic 4852-b water leaking
Water leaking, seal not good
SOURCE: My Bunn coffee maker is leaking water
  1. Remove nut and gaskets
  2. Mix small batch of JB Quick (a version of JB Weld)
  3. Spread JB Quick with putty knofe or wide screw driver on bottom and top of degraded plastic around hole
  4. Let dry foe four or five hours (speed us slightly with hair dryer)
  5. Smoothe hard but uneven surface with fine sandpaper
  6. Reassemble
Posted on Oct 28, 2008
  • 3289 Answers
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Posted on Dec 02, 2008
EsWorld
  • 1618 Answers
SOURCE: My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
Posted on Jun 20, 2009
  • 4 Answers
SOURCE: My Bunn leaks out of the back of the machine when
I have the same problem and I took the coffee maker apart to find out why. The hole in the black pastic that the water flows through to get into the stainless steel tank may not have a tight fitting with the plastic and that's where I had water leakage. I'm looking around for a fix, but it may have to be done with a mixture of adhesives and miscellaneous rubber plumbing washers. Unless somebody knows where to get parts for a really old coffee maker that still makes great coffee! Anyone?
Posted on Oct 15, 2009
  • 454 Answers
SOURCE: Should I leave the Bunn Pour Omatic Coffeemaker
Yes, the coffee maker keeps a tank of water pre-heated, that is what allows it to brew coffee in a couple of minutes. The exception would be vacation (away from home) or other times when you won't be using it for a few days. Visit www.bunnomatic.com if you have lost your user manual.
Posted on Dec 31, 2009
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
How do you get a bunn pour omatic coffe maker to pour water into the hopper. I put water where it's supose to go it heats up but no water come out. Is there something I'm not doing. Its an older one.
did you pour in another pot of water? It heats up the reserve tank so you always have hot water instantly, but to get that water you need to pour in another pot of water to replace it.
Manual:
www.bunn.com/sites/default/...manuals/10424.0000.pdf
May 12, 2016 | Bunn Coffee Makers & Espresso Machines
Leaking water out of back of unit
if the hole is near the top it is an overflow hole- so you can not put in to much water. unplug coffeemaker ,and take to sink- turn over and drain completely. set it back up and try again filling coffee put to just the top cup line and no more..
Dec 22, 2013 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
My bunn pour- omatic only gives warm water --any suggestions?
TRY RUNNING WHITE VINEGAR THREW THE TANK, IT MIGHT BE ALL CALCIFIED AND THIS IMPEDES HEAT TRANSFER .. MIGHT NEED TO DO IT A FEW TIMES , DO IT TILL THE WATER IS CLEAR. JAY THE PUMP GUY FL
Feb 03, 2012 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
The tray where I pour the water is broken at the seal where the water goes into the tank. Where can I get a replacement?
You can call Bunn Home in Springfield, IL at (800) 352-2866. They have a kit which you can try at no charge. If that does not work they will replace your coffee maker at at discounted price provide you send the old one in. Hope this helps.
Apr 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
160 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
