Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Burner flame yellow - Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
    Problem Solver:
  • 27 Answers
If you have LP gas, you may still have Natural gas Orifice's. So it would need to be converted.
Posted on Jan 14, 2013
Yellow flame
The problem is with the orifice leading to the burner. If it is not centred then you will get yellow flame. Or you are impeding the flow out of the burner and it is not mixing properley. I would pull the burners apart and make sure everything is clear and the orifice is centred.
Apr 14, 2014 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
How to adjust side burner on weber grills
Burner could be blocked try cleaning the burner then you should be able to adjust air mix Lpg will a bit of yellow in the flame.
Jun 14, 2013 | Grilling
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
I have a blueflame calor gas heater and the flame is mostly yellow
it sounds like the burner could do with cleaning bust in the burner
Jan 02, 2010 | Heating & Cooling
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
63 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
