Question about Zenith B25A11Z 25" TV
TV comes on when it wants to
It keeps going out and then sometimes it acts like there is no cable hooked up to it can some one help me fix it?
    President:
  • 2,992 Answers
If the TV "goes out" meaning that you lose tuning (picture gets very snowy, disappears totally, etc.) but the power stays on and is otherwise normal, the trouble is often because of bad connections inside the tuner.
It is possible to remove the tuner from the circuit board, open it up and resolder the connections that typically go bad. (Usually they are solder joints connecting the ground traces along the edges of the tuner circuit board to the metal box it mounts in, and some other ground points on the board. Often they are visibly cracked.)
To this requires electronic soldering skills and the tools to make the repair. It is possible to do additional damage to parts because of small connections, fragile parts and so on), so this may not be something you want to try as a first project. But if you can do the soldering and are patient, it is possible.
On the other hand, if "going out" means the set suts off completely, there are too many things that might cause this to offer any suggestions for things you might try on your own.
Posted on Jan 23, 2009
I have no sound coming out of my speakers for the reciever that is hooked up to my tv. i have 2 of the spekers hooked up and the audio cable plugged in to the tv but im getting no sound from the tv t
hi,try going into your tv setting and see if thers a setting for ext speaker as sometime ther is ,this is the place i would look and the only place i would think the fault would be ,you say audio cable i take it you mean
rca cables [two cables] if not check them but i dont think its both of them faulty,def in setting somewere.good luck
Jan 21, 2013 | Kenwood Audio Players & Recorders
Craig, tv dvd player Model: CTV1703
I purchased this portable tv and I can't set up the channels..keeps telling me there is no signal. What am I doing wrong
Nov 29, 2010 | Craig Televison & Video
Need help with SSI Cineplex 1500 Home Theater hook up..have all speakerwires hooked up,have 2 wire rca cable hooked up to input on system,going to output on satellite reciever, whaen I hit test tone I hear...
Hi, Hiss soundare from RCA cables.You need to reconnect again,but using a different cable for connection.
And also sometimes home theater acts that way during test mode, Check the manual and you will see how to set the home theater to see the mode that will allow all speakers to work. It's a normal thing when connecting a newly bought home theater.It the settings.Use the manual.
Take care.
Jul 07, 2010 | Audio Players & Recorders
Hooking up a tv to a surround sound and to a dig cable box
Ok, hook the cable box up to the reciever audio/video, find the monitor out from the reciever and plug it in to the TV input. sound will come from the reciever this way onto your speakers and the Tv will act as a monitor
Feb 02, 2009 | Audio Players & Recorders
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Vizio vp50HDTV10A Plasma Vidio and Audio on and off
Odd problem for this model.
If:
* you are certain the popping is coming from the speakers and
* the video and audio come back on after going out (without reset) then
the issue will be with the main board and will need to be replaced.
Call Vizio customer service, they extend warranties sometimes.
Dec 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
It shuts off on its own will
something is getting hot and a fan could keep it cool and it might help to keep it running.longer . I have tv shop and ones like your that come on are hard to fix unless it fails all the time,I would suspect cold solder joints on board and is fixable but wait fot it to fail all the time before you get it fixed
thanks DOCTOR VIDEO
Apr 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Zenith B25A11Z 25" TV Logo
43 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
