Question about Motorola Mobility V220
Call Divert There doesn't seem to be a call divert function in any of my menu's. When I go to personalise my phone goes blank and goes to start up
RESET SCREEN
Posted on Jul 31, 2007
SOURCE:
Call forwarding
1. Menu, 2. Select "Settings" 3. Select "Call Divert" 4. Select "Voice Calls" 5. Divert all incoming calls 6. Insert your forwarding number.
This function can also usually be done through your service provider. (service availability is subject to the carrier and their available services. Charges will apply).
Jul 15, 2013 | Motorola Mobility MOTO W755 Cellular Phone
Need instruction on how to call forward? Why charging to what is indicated as FREE?
You can now divert important calls to another mobile phone or landline if you are unable to take a call in case: you miss a call, are busy, are out of reach or phone switched of.
Activate
  • Go to the 'Call Divert' menu on your mobile phone
  • Select 'Divert if out of reach' option
  • Select 'Activate', followed by to other number option
  • Enter the number in the to other number section
  • Your Call Divert service will now be selected
Deactivate To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
Also:
To forward all calls:
  • to start, enter **21*number #
  • to stop, enter ##21#
To forward calls while you´re speaking to someone else:
  • to start, enter **67*number #
  • to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
  • to start, enter **61*number #
  • to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
  • to start, enter **62*number #
  • to stop, enter ##62#
To cancel all preset conditions:
  • enter ##002#
You will not be charged for activation or deactivation of this service. Only the call divert will be charged as a separate call.
Jul 23, 2011 | Cell Phones
Need instruction how to call forward?
Activate
Also:
  • enter ##002#
How will you activate call divert
Go to menu > settings > call settings > call divert.
Choose your method of call divert, choose activate, select the phone number you want to divert the call to or voice mailbox number and that's all.
I hope you understand the above....
Good luck.
Mar 07, 2011 | Nokia 2626 Mobile Phone
Nokia active incoming call diverts problem:
I hope you have activated your call divert function so your are not able to get the incoming calls.
To deactivate the diverts,
Menu > Settings > Call > Call divert > No Call Divert.
Select No Call Divert it will deactivate all the call diverts and now you can get the incoming calls.
Thanx
Aug 04, 2010 | Nokia 6300 Cellular Phone
Can't receive calls
This setting is network related.Your phone sends a request to the network provider for any such facility and it must be activated by the network to take effect.Some phones (depending on the qualityand make) also may not be able to use this feature.
To activate call divert make sure both the diverted phone and the diverting phone lines are credit recharged.The network provider does not offer this service at anytime for free.
Aug 16, 2009 | Lands Phones
My incoming calls go straight to voicemail and phone doesn't ring at all. How do I change this? Thanks
Friend,
goto Tools
then call
then Call divert and cancel all call diverts
then back to main menu
then to profile
then to general
then to personalise
then select a sound THAT IS LOADED ON THE PHONE- THEY MAY HAVE BEEN ACCIDENTLY DELETED
then select a reasonable volume
then save all and have someone call you
PJH1
Jun 06, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Can't turn off call divert?
open menu, select settings and select call.
In this there is option call divert, select that.
In that select cancel all divert or select option and in that select cancel all divert. by doing this your problem will get solved....100%
Apr 23, 2009 | Nokia 6300 Cell Phone
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Dec 17, 2008 | LG CE110 Cellular Phone
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
Motorola Mobility V220 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
