Question about Maytag MDE2400A Electric Dryer
Whirlpool duet dryer continues to run after cycle
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Whirlpool duet dryer won't heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Jul 02, 2014 | Whirlpool LAB2700ML Pedestal Drawer for...
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MDE2400A Electric Dryer Logo
13 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
