Question about Whirlpool LER5636P Electric Dryer
Dryer not heating up
Tumbler turns, not clogged, timer knob not turning.
  • 750 Answers
Hi ya,
Welcome to
This sounds to me like the the timer switch is faulty and needs to be replaced.
Web site and schematics below. You can open them into the whole window and buy parts there too!
Thank you Huuum
Please leave a solved rating before you sign out
Posted on Jan 23, 2009
  • 1,214 Answers
If the timer knob does not turn in a clockwise direction, then chances are the timer is bad.
Heating is a different issue, although, if the timer knob will not turn, then it may not be at a position that turns the heat on.
Replace the timer, then check the heating. If the heater then works, then the problem was in the timer. If it doesn't, then we need to look at problems within the heater circuit.
Reply back what you find out.
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ... > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
The dryer is not getting hot to dry the close, but there was something on the water heater pushing on a red button
unless I'n missing something the water heater has nothing to do with your dryer. If you have an electric dryer and the tumbler is turning then you have electricity to the dryer. If however the tumbler is not turning check the wall plugin. It probably is a CFI plug and may need to be reset.
Dec 21, 2014 | Maytag Clothes Dryer Almond Timer Knob...
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
see this causes and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
Timer knob not turning and its not heating up
If you are setting the knob to begin a cycle AND the drum turns when you start it AND the timer knob does not advance, the timer is likely defective.
Some dryers with truly automatic cycles (using moisture or temperature sensors) will not advance the timer if there is a no-heat condition due to a bad thermostat or heating element. This would show as the dryer tumbling a load forever and the clothes are cold and wet when checked.
If the dryer will not do anything at all AND the timer knob does not advance, check the power (circuit breaker/fuse), then the dryer door switch. When the door switch is defective or the door isn't fully closing, it stops everything, period. There is a thermal fuse on some machines that will also cause this problem.
Good luck from Detroit, MI.
Oct 19, 2011 | Dryers
How to replace an ignition switch on a 1994 lincoln town car?
Get a nail, along the key are ignition part youll see a small acess hole it will be under wear the key goes in. Okay put the nail in the small hole. at the same time have the key in the ignition as you turn the key it will catch the igition switch releas knob. there you pull the whole key out and with it come the ignition part this is called the tumbler. Okay look at the tumbler do you see that little knob that held it in . Now for the new tumbler to be installed put the key in the new tumbler and work it in till it feels that it will slide in (at this time there will be no use for the nail).once it is in turn on the car on check its movement and if all is fien the job is complete.
Apr 23, 2011 | 1994 Lincoln Town Car
The timer control knob seems to be free wheeling & no longer clicks when you turn it. We looked at a web site that sells parts & think it might be the timer, does that sound right?
Hi, It has something to do with the timer, that I can tell you.
Some timer knobs must be pushed in to rotate them, Others timer knobs must be pulled out. And, of course, some timers you just turn.
If you can turn the knob and it spins but the pointer on the timer does not spin. It is the knob assembly itself. Possibly just loose.
If you can turn the knob and the pointer on the timer rotates freely without any type of click or resistance, The timer is failed.
If it is the knob, you should be able to pry off the center piece with a very small screwdriver and check to see if the know is loose.
Maytag has used different types of mechanisms in their timers. So good investigation will help in the determination.
If the symptom you are experiencing is that the machine doesn't run. Other things can be the cause of that. An inoperative door switch will render a clothes dryer silent.
I hope this helps,
Good Luck,
Jan 16, 2011 | Maytag MDG9606 Dryer
Not heating/timer knob not turning . the dryer works but is not heating and i noticed that the knob is not turning therefore it does not shut off just keeps running.
HI. The timer device is responsible for initiating the heating cycle. If the dial plate is unable to advance, the heating circuit will not operate correctly, thus, preventing proper heating. Another indication of timer mechanism failure will be an un going cycle. You have stated that the unit Will continue to run, without stopping. This is caused by the defective timer device.
In most cases, the actual timer motor will Fail. This motor is , essentially, responsible for the forward motion of the dial plate.
I recommend to replace this damaged timer device, asap.
Jan 19, 2010 | Whirlpool Dryers
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Whirlpool LER5636P Electric Dryer Logo
200 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
