Question about Dometic RM2852 Refrigerator
I need a door handle for dometic rm2807
The door lock on the handle broke need a replacement
4 Suggested Answers
  • 234 Answers
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Posted on Dec 27, 2009
imufo2
  • 3773 Answers
SOURCE: freezer temp reaches 20 degrees refridgerator wont
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 29, 2011
  • 5370 Answers
SOURCE: dometic rm2807 keeps going to
Here's some info regarding the check issue you're experiencing:
Problem. Unit controls go to "check"
There is a common problem with, Dometic RM2807 or RM2811 and most later model Dometics with upper controls. The refrigerator's "check light" comes on or the refrigerator just shuts down seemingly for no reason. Another common problem occurs while on 120v. The refrigerator might switch to gas or just shut down even while you have a good 120v supply.
Answer.
Dometic RV refrigerators with the push button upper control boards have a problem with the main power boards. The power board components are encased in yellow epoxy, reducing heat transfer. This tends to cause them to run too hot which in turn can often cause the power board to fail completely or cause problems such as listed above. We have found the only effective repair is to replace the power board. We do not use the Dometic replacement as they too can fail. The Dometic replacement also requires you to rewire the board and gas valve. The only board we recommend is the P-711. The P-711 not only will fix these problems but does not require the rewiring. It uses all the standard wiring.---------------
All the Dometics with the push button upper control boards have a real problem with the main power boards. The components are incased in yellow epoxy and this makes then run too hot hence the board fails. And when the board fails, it gets hot and stops working, due to getting short and this causes the unit to go to " CHECK" again n again.--------------
Dinosaur P-711 power board needs to be replaced to fix this problem.------- To get this power board click the link below and you can order it.---------- http://www.rvpartsnow.com/dometic-micro-p-711-circuit-board-replaces-293xxxx ------------ This will help.Thanks.Helpmech
Posted on Aug 11, 2011
How do you replace a door latch on a Dometic RM2652 fridge?
Remove the two screws holding the latch/handle assembly on. With the door open, roll the handle outward toward the edge of the door. Then install the new handle assembly.
Aug 31, 2013 | Dometic RM2652 Refrigerator
How do I fix the door/lock of my 1991 Acura Integra? I can only open the driver side door from the outside
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
Jan 11, 2011 | 1991 Acura Integra Hatchback
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
The 5th door of my 2006 Sequoia was very difficult to open. Today the handle broke and I can no longer open the door.
as it broke, you need to replace the handle only! then use Anti rust spray to the lock from time to time... it'll be ok! the lock is exposed to accumalation of dust, dirt and lubricants as it is in the bottom of the door, so you need to take more care about it. handle will cost you $60 to $72
if you have some skills you can do it your self, or take it to a technician
May 25, 2010 | 2006 Toyota Sequoia
The interior door handle on the driver's side of my 2000 Tundra does not open the door. The exterior door handle works fine. I would assume the cable has broken on the door latch portion. What is the...
remove the screws that fasten the interior door panel to the door.  Visually inspect the handle assembly. there will be two cables that connect the handle and lock button to the door lock assembly.  I would bet that the L-shaped end of the interior door handle cable broke.  The replacement is self explanatory for the handle. Google the door lock assembly which isn't as visable.  Bob
Jan 10, 2010 | 2000 Toyota Tundra
Dec 27, 2009 | Dometic RM2652 Refrigerator
Door lock broke
rod is very hard to break it just the handle the clips broke so you just need a new handle
Feb 15, 2009 | 2003 Chevrolet Silverado 1500
How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
Jan 19, 2009 | 1996 Ford Explorer
The driver side door lock broke on my 98 jetta door want open
according to my partsman (who has had great advice for many years), you do not have to remove the door panel to replace the door handle which contains the cylinder lock. the handle is released with a screw which you can see when you open the door. you will need a starhead screwdriver or socket. A new handle costs around $40 at a parts store in my area. call around for a locksmith who will re-key your key to the new lock or use the key which comes with the new lock, your choice. i am in dealing with this also
Jan 02, 2009 | 1998 Volkswagen Jetta
Dometic RM2852 Refrigerator Logo
209 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
