Question about DPA Microphones Audio Players & Recorders
DPA-4088-F WIRELESS MIC REPAIR
Our church has a DPA 4088-f mic that needs repair at the back side of the headband. the wire sheathing has started to pull away, (exposing bare wire) at the rubber flexible spot where the wire meets the metal band, and is picking up sound at the back of the headset. I've tried taping it up, but it's not helping at all. These mics are very expensive, and was wondering if its worth trying to get fixed, and if so where I would take it or send it, and how long it would take. Or is even worth trying to fix it?
Any advice would be greatly appreciated....
-E
  • ecraft23 Jan 24, 2009
    Thanks for the info!
    Scholar:
  • 140 Answers
Yes they are very expensive and very much worth getting repaired.
Call DPA and find out who/where the closest service center is for your area.
DPA Microphones, Inc., 2432 North Main Street, Suite 200,
Longmont CO 80501, USA
Telephone 303-485-1025
Posted on Jan 23, 2009
Repair cable on shure wireless headset mic
If you unplug the mic, does the crackling stop? It so, replace the mic.
Feb 03, 2012 | Shure THD Wireless Headset Microphone...
The mic boom on my PX21 headset is too loose and will not stay in position any more. I have only owned the headset for about 3 months, but I didn't use it for the first month and it started about 1 month...
Well, if you don't want to send in the headset for warranty repair, your solutions are rather limited. With that in mind, any solutions will probably be sub-par, compared to getting a new headset.
Anyways, you could try to MacGyver it a little bit. I've had this problem before, and it was solved nicely by a little bit of glue from a hot-glue gun. The only problem is that if you ever need to move it, you have to re-glue it.
Alternatively, some thin metal wiring could be wrapped around the mic and the headband and used to support it.
Honestly, your best bet is the warranty service. Sorry about that. Try the hot-glue though, worked great for me.
Mar 03, 2011 | Video Game Consoles & Games
I am getting a lot of hiss when I record low
it is not a problem there are many problem
Aug 23, 2009 | PreSonus Computers & Internet
My new wireless mic wont connect to my wired controller
Hi, i think ur number 1 is configured for wireless functionality. So it will not work when the wire is connected. Try configuring the mic to work when the wire is connected as well. There should be a setting for it in the mic software. It should work after that
Jul 08, 2009 | Microsoft Xbox 360 Controller
Eighth in microphone jack/wire bad
You might want to check the other end as well. Take a ohm meter and check the wires to make sure their is a reading on both.The wire you speak of is called shielded cable and there should be no reading between the sheilding and the center conductor when they are seperated from the capsule. If there is a reading you have a short.To clarify, the outer sheild should read at or near zero when you check @ each end as should the center conductor ( the white ) wire.There should be no reading between the two (the sheild and the white) when they are unhooded @ each end. Also when the capsule is unhooded you should get a reading between the two terminals, if not the capsule is open and needs replacement.
Apr 05, 2009 | Sennheiser 100/500 G2 Series Wireless...
Vocopro VHF-3300 Dual Wireless MIC - one is lower than the other
If the unit was "repaired" correctly, you would not have that problem! Have repairs been attempted?
Apr 18, 2017 | Vocopro VHF-3300 Microphone
ED 8000
You need to replaced the "voice coil". that thing that youve been desoldering and soldering is the voice coil. It has two wires- white and black. it is already grounded and need to be replace (the fact that it humms..). my company distribute wow magic sing here in Philippines and we can easily repair that.
Dec 25, 2008 | Magic (ED8000) Professional Microphone
Telex prostar wireless mic.  leads came off of mic element.  One green wire and one black.  Which one connects to center of element and which connects to rim.
Hi..
The rim is "ground" or the (-) side of the mic.
Find out which wire goes to ground or a (-) on a battery.
Solder that one back to the rim
Dec 11, 2008 | Telex FMR-200H Professional Microphone
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
598 people viewed this question
Top DPA Microphones Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DPA Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
