Lexmark S405 Interpret All-in-One Color Inkjet Printer Logo
Want To Scan long paper (16 inch long) on Lexmark Interpret S405 Wireless All in One
Hello, i need a help... I have a Lexmark Interpret S405 Wireless All In One Printer. Sometimes i need to scan some papers which are longer than A4 size papers, like 15/16 inch. I tried to use its 'Auto document feeder board' for full scanning. It took the full paper but it only scanned the portion which is in A4 size. Its not scanned the last portion. Also there is no option to select the size that i want in my recommended software(Launch Lexmark Printer Home). I want to scan those papers which is longer than A4...Is their any tricks or any soft to do that , like i can manually select the scanned paper size ???....It will very helpful for me if it is possible... Thank You... :)
5 Related Answers
Anonymous
  • 328 Answers
  • Posted on Aug 02, 2007
SOURCE: Techinical glitch?
This unit is not well made at all. I would suggest you exchange it if it is still under warranty. In the future, buy a HP or Epson with extended warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Oct 29, 2007
SOURCE: Lexmark F4270 Paper Jam Problem
Go to the menu and make sure it is set to Letter and not Legal size.
Anonymous
  • Posted on Nov 24, 2007
SOURCE: Can Scan A5 size duplex
The software on my X4500 unit allows duplex scanning of A5 paper. Updating the firmware and software is fairly easy if you need to.
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Aug 25, 2008
SOURCE: Good Morning, I have a
did you specify that 1 for long distance calls in the menu?
Anonymous
  • 32 Answers
  • Posted on Apr 19, 2009
SOURCE: info on the Lexmark X125
It appears that this machine is multifunctional. You can print color copies with it. You will need drivers to make it function. You can find everything you are looking for at the link provided here. Drivers, available accessories, specs, etc.
http://www.lexmark.com/lexmark/product/home/272/0,6970,204816596_653399443_243436816_en,00.html?tabId=7
Good luck. Let me know if this does not work out. I will see if we can find you something else for this machine.
I have a s405 interpret stating I have a paper jam. I have went through and cleaned everything and there is no paper jam anywhere that i can see. What do I do next?
There could be something blocking the paper path. Try to get a flashlight and check if there are any foreign objects inside the printer. If you can turn the printer upside down with the scanner cover open, try to do that and shake the printer. If there are foreign objects inside, it should fall off.
If it doesn't help and your printer is still under warranty, contact our technical support team to have your printer replaced. You can find our contact number at www.lexmark.com.
How do you make 8.5 x 14 copies on Lexmark Interpret S405 AllInOne
Please refer to the Lexmark S400 Series User's Guide from the Lexmark website for more detailed instructions on how to copy using your model.
I hope this helps.
I've lost the cd that came with my s405 printer
Please visit the Lexmark website to download and install the Lexmark Interpret S405 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
I cant print wireless and how do I set up the scanner to work?
Your wireless communication problem could be caused by several factors. Try to check the status of the WiFi light on the printer. Here's How to identify a Wireless Communication Problem and Resolution Tips.
For your other concern, make sure the printer driver is installed on your computer. The Lexmark OCR scan software, used to scan documents for editing, is available only in the install disc that came with your printer.
For the step-by-step instructions on how to scan, please refer to the Lexmark S405 User's Guide.
Windows 7 64bit, home network. Lexmark interpret s405 all in one.Trying to scan with windows fax and scan. can printer with no problem. windows fax and scan cannot find scanner. I look in device manager...
Try to re-insert the installation disc that came with your printer. Run the disc and make sure to install the Lexmark scan driver. If you have a firewall enabled, make sure to allow all access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
1helpful
I have obtained a Lexmark Interpret S405 printer (secondhand) but there is no installation disc. How do I get my hands on one?
The link below take you to the Lexmark Interpret S405 page to download drivers and software. You may have to change your operating system (OS), the default is Windows XP 32-bit. You want to click the "More>>" button to find the link called "Complete drivers and software for setting up,....". You probably dont need to update the firmware unless there is a problem after installing.
Lexmark Interpret S405 Software and Drivers
I hope this helps you. Have a great day!
8helpful
3answers
LEXMARK 405 COMPUTER SAYS PRINT HEAD PROBLEM AFTER HALF THE JOB WAS COMPLETED . PRINTER ONLY 2 WEEKS OLD
Sound like printhead problem... ask from lexmark for replace (call them +1 800-539-6275). If they refuse to give you, than search on amazon for it... here Amazon com LEXMARK 405 printhead. I hope this was helpful. Cheers
8helpful
2answers
I have lost my lexmark interpret s 405 software. how can i download now
Hi john
No need for disc, don't worry.
lexmark interpret s 405 drivers (win 7/8) can be found at
driverupdate us . (32/64 bit)
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
