Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
I have a coin in the paddle of the dryer
The model # is LSG7806A
    President:
  • 373 Answers
The following is the link to the internal diagrams to your model, might help you in disassembling.
click here for internal diagrams
The link has few models with the same model number, choose your model and i hope it works out.If there is anything else i can help you with, then please do post comments.Good luck.
Posted on Jan 23, 2009
Coins inside Kennmor dryer drum paddles
You will need a thin putty knife. Run the drier to get it warm inside. Use the putty knife to slip under the paddles and lift them just enough to let the coins drop out when you rotate and raise the drum on that side.
Aug 23, 2011 | Kenmore Dryers
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
GE Dryer (new) makes noise
few possibilities here,idle pulleys could be wearing,front drum guides could be wearing,back drum bearing,bit early for these problems though,but sometimes coins get lodged at the drum paddles inside located 120degrees apart which wouldnt be anything to worry about if you can verify this,hope this helps
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
Coins inside panel inside
the screws on the drum will take care of that. looen the screws and turn the drum. try each paddle till you dont hear them anymore.
Apr 19, 2009 | Dryers
My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
Mar 02, 2009 | Kenmore 63942 Dryer
Is there a schematic for the Kenmore Elite Oasis gas dryer model no. 110.7703*, 7704*? I think a coin or something got inside and it now makes a noise when in use. I cannot for the life of me figure out...
you can remove the lower acees panel ( 3 1/4 screws across the very bottom of unit, this will give you acess, to the insideto better pinpoint where noise is coming from, also across the top of the back of the unit is 3 screws holding down the top assy, by removing this youll be able to access the screws hodling on the inner drum paddles( incase the coin(s)), has gotten between there
Apr 24, 2008 | Dryers
Maytag LSG7806A stackable washer/dryer - dryer not working
Deb, as long as the ignitor is glowing, it's probably your coils on the valve. Look at number 13 and 14 on the attachment. Part number for the booster coil is 306106 and 306105 for the secondary coil. Not a hard job, the coils slide right off after removing a screw and then replace the harness. Catriver...post back.
Oct 14, 2006 | Maytag LSG7806A Front Load Stacked Washer...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
300 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
