Question about Hotpoint RLA80 Refrigerator
Ice of the back of refrigerator
A wall of ice is forming on the back of the refrigerator (a Hotpoint RL83) since the thermostat has been replaced.
  • Anonymous Mar 28, 2008
    My fridge is working as a freezer i have ice about 4 inchs thick on the back and unless i put items in door they freeze. i have defrosted and made sure temp is set to 1 the little hole towards the back at the bottom is clear.
    please help would this be the thermostate
    Kerrylea
    President:
  • 1,462 Answers
Probably the wrong thermostat fitted - the cut back temp varies and is important
Posted on Jul 09, 2007
SOURCE:
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
GE top freezer fridge forming ice on wall of freezer
Hi the thermostat could be the cause of your problem but check the temp of the compressor put your hand on it and it should be about room temp any hotter and this needs replacing also look on the pipes at back where they run on the outside check as much as you can and see if it has any frost on any of these pipes.
As its forming on one side then it might not be thermo but check compressor first and make sure its not running hot ok then get back to us
Apr 26, 2008 | GE Hotpoint Top-Freezer Refrigerator
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
Hotpoint side by side has warm fridge and ice build up on back wall of freezer side, barely keeping ice frozen.
OK, you will need to replace the "defrost thermostat" that is located on the coils in the freezer. Here is the part to order. If that was the problem before, the repair tech sold you a part you didn't need. I can't stand service techs that do that! Anyways, keep me posted.
Nov 28, 2012 | Hotpoint HSS25GFP Side by Side...
LEC L6046W FRIDGE - ICE/FROST INSIDE THE BACK WALL. MOTOR IS RUNNING CONSTANTLY.CLEANED ALL THE ICE OFF BUT WHEN SWITCHING BACK ON, WITHIN 10MINS THE ICE,FROST IS BACK?
1.I think you might have a thermostat problem it is over cooling the system and doesn't shut off when it is suppose to. Replace the thermostat
2.If the door seal is broken or the door is not closed shut with the seal magnet nice and tight against the fridge it will form ice inside the fridge as well. Replace the door seal. (this is very common with old fridges)
Sep 06, 2009 | Refrigerators
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice crystals forming on walls of freezer and refrigerator nor getting cold
you have a problem with your defrost system, unplug appliance - remove panel from back of freezer, test defrost heater, if heater good test defrost thermostat - replace bad part....if this is too technical call a repair guy...should cost between $120 - $200 to fix depending on which part is bad.
Jun 23, 2009 | Hotpoint Refrigerators
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
Hotpoint RLA80 Refrigerator Logo
519 people viewed this question
Top Hotpoint Refrigerators Experts
jasbo
jasbo
Steve Allison
Steve Allison
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
