Question about Ninco Toys
Nincoair 535 hellicopter wont take off and just spins
I cant get hellicopter to charge
Maybe the battery is dead. Check the charging system/power supply. Maybe it's malfunctioning. Maybe inputs are wrong and check to see if they are working in proper order.
Jan 01, 2015 | Cameras
How do I attach mjxf45 tail motor to v913 circuit board (esc red wire black wire and white wire?thanks cessnaman
Both hellicopters have the same wiring for the tail motors (white blue) and I think the same motors. Anyway the wiring for any 3 cable esc with any 3 cable motor doesn't have a standard. If you place them "wrong" the motor will not spin to the side you want and you have to make another combination. Generally on rc planes, bellicopters, cars etc the three color cables have black color for ground red for voltage and white for singnal. You may also see black , red, wellow or brown , red, orange coloring with the same meaning. These cables are used most on receivers and peripherals connections.
Oct 01, 2014 | WL Toys WLToys V913 Large 4 Channel 27" RC...
Hellicopter wings
You will need to buy replacements and also check the grip sets which the blades connect to are ok as well.
Kind regards, Julian
rccontrolfreak.co.uk
Jan 04, 2013 | SYMA Toys industrial Syma S032 Ready to...
I have a virago 535 when i go to start it the starter just spin`s pop it in to gear pull back a couple times an then it will catch to start ..help what do i need to do
Hi, Jamie557255 the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
94 XV535 starter problem
VX535 starter clutch install 1of 5
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Sep 12, 2011 | 1997 Yamaha XV 535 Virago DX
My starter spins but doesnt engage
The problem is with ignition.Check it and check the spark-plug.
Aug 26, 2009 | 1994 Yamaha XV 535 Virago DX
94 yamaha 535 virago sounds fine, just wont start
Check to make sure your getting gas by pulling off the hose, if no gas comes out your petcock is clogged. If this is the case blow air up into the hose, and if gas comes out now your tank has to be cleaned out.
Jun 17, 2009 | 1989 Yamaha XV 535 Virago DX
Toys Logo
20 people viewed this question
Top Ninco Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Ninco Toy Expert? Answer questions, earn points and help others
