Question about Sony SNC-RZ30N Network Camera
Setting NG My camera always take a public IP ,When i changed it it appears message "Setting NG" ? what shoud i do ?
Make sure you are using a crossover cable. A straight through ethernet cable will not work for talking with your computer. Next, go to your network connections. click on TCP/IP properties and enter in for the IP address 192.168.0.101 and a subnet mask of 255.255.255.0 apply it. go back to network connections and disable then enable your connection. Now go to the Sony IP setup program. Double click on your camera when it appears. Don't forget the default address of the camera is 192.168.0.100.
Posted on Aug 09, 2007
    Novelist:
  • 135 Answers
From the Manual for this camera model, on page 22: "The IP address setting in the Wired LAN setting section (see page 26) on the Network setting page and the IP address setting in the Wireless LAN setting section (see page 27) cannot be set." So... it's possible that you may not be able to change the IP setting that you were trying to change. Or it could be that you are trying to assign an IP address that is not allowed. In any case, the Manual for this camera is available at the following website, and you may be able to find the answer to your question in this document: http://bssc.sel.sony.com/BroadcastandBusiness/docs/manuals/usesguidesncrz30nv4.pdf Hope this helps! ;)
Posted on Aug 05, 2007
I need to know how to complete my setup I got as far as the setting screen where they ask u your IP address etc. Now I can't get in to complete the set up. What do put in those blanks that ask for you
If you are in the Router setup, (and not a PC setup,) then that would only apply if you had a "Static" Public IP address, (this is an address that never changes, vs. 'Dynamic' ones that do change.) Usually only a business would have 'static' Public IP addresses, and the Internet Service Providers (ISPs) charge extra for them.
Without knowing more about the make/model Router you have, it would be difficult to give you further instructions, but look for settings that would assign the IP address 'automtically'
Oct 12, 2014 | Computers & Internet
How to convert local ip camera addresses to ip addresses to connect from internet
depend on what brand and type of the ip camera that you use.
in order to be able to access from internet:
- you need to use a router that connect to a switch and the camera
- the router must have UPnP Feature & Port forwarding.
- just in case your public ip address is dynamic, you will also need a ddns for redirection.
The basic concept is, you have to configure the network setting of the camera according to the router as a gateway.
usually, in the network setting, you will find a http port number.
change this number from default ( 80 ) to another number from 0 to 65535 ( example 50010 or 40000 , you can choose freely, it's recommended to use port above 50000 )
then find the portforwarding function in your router, then set the port number to the ip address of the ip camera.
if it's successfull, you can directly access the camera from the internet by entering your public ip address and the port number on your browser.
for example : http://itcomm-streets.viewnetcam.com:50001 << my ip camera demo unit.
Jul 02, 2012 | Android Apps
How to forward port for a IP camera on a Huawei 655b modem ?
You can't port forward on a modem. On a router, yes. You just need to set the a static IP on the camera outside of your DHCP range. Then select a port above 1024 and set that port to point to the static IP. You should only need to port forward UDP. Optionally you would want to setup a dyndns account since your public IP from your ISP is dhcp and therefore doesn't always stay the same.
May 30, 2012 | Computers & Internet
How do i port forward to a minecraft server to my wireless laptop easy?
For this example lets say the minecraft server is on local ip 192.168.0.5 and using port 21000, default is 25565, for its connection in the config file. If your laptop is in the same lan (network) you would run mine craft and connect enter a server ip of 192.168.0.5:21000 No port forwarding required. If you want to access this server from outside of your network you will need to setup a port forward for 21000 tcp to go to 192.168.0.5. You would also need to know your public IP. www.ipchicken.com or just google "what is my ip" So now armed with your public IP lets say 74.132.132.5 when you want to connect to your server on your local network you would open minecraft and type for the server address 74.132.132.5:21000. Your router will see that it is going to 21000 and it will check your port forward rules "Oh this goes to 192.168.0.5". Please note most home users have dynamic public IP's this means they can change so you would have to keep checking your public IP to give to people. You can sign up for what is called Dynamic DNS such as DynDns.com This will associate a free domain name you choose to always point to the correct public IP you currently have assigned at home.
Comment back if you have further questions.
Oct 25, 2011 | 2wire (2701HG-B) Wireless Router
Silent update Failed of Hid IP NG
hello
i have hide ip ng 1.6 program.
get silent update 2 failure message, can u solve my problem? it says that i need to exclude a program from the firewall. I did but the same happened again. I turned off the firewall and the same happened! please help
Apr 21, 2011 | Hide IP Soft Hide IP NG
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Warning message
PSD NG is an error dealing with the OIS [optical image stabilization]. It can be fixed, it is not as terminal an error as many have rumored it to be. The caps could be a cause, but very remotely THE cause. You can have the camera sent in to Pani, and they will fix it, and you will get a bill for $300 - $600.
However the main cause for so many of the dvx100 series to have the psd ng error is loose cables. If you feel sure of your self with a screwdriver, tweezers, & forceps, you can make the repair yourself. In simple terms, all you need to do is reseat the ribbon cables. Follow the steps & photos here:
http://www.dvxuser.com/V6/showthread.php?t=172290
I did this repair with great success. It was a nerve wracking two hours, but I have not had the error reappear since. I got the camera from someone dirt cheap, [read 1/4 value], because of the psd ng error. I made the repair & not only have a fully operational unit with beautiful pictures, but I also quadrupled the value of it.
Apr 24, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Sony dcr hc30
I wish to transfer my DCR-TRV480 NTSC video to my PC. I have set my camera to Play/Edit mode. However, when I insert my USB cable into my video camera, the message "Disconnect the USB cable before changing the setting" appears, preventing me from playing/transfering my video. What can I do?
Apr 11, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Wap settings for motorizr z3
Regular rogers wap
(not using phone as modem)
uses navigate plans
http://www.shoprogers.com/store/wir...ng/overview.asp
apn: goam.com
username: wapuser1
password: wap
IP 208.200.067.150.
or
172.025.000.107
Rogers Media settings
(for MMS/PICmessaging)
http://www.shoprogers.com/store/wir...remessaging.asp
apn: media.com
username: media
password: mda01
mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings
(to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time.
requires access to a Data access plan
apn: internet.com
username: wapuser1
password: wap
ip: same as goam, 208.200.067.150
Dec 06, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Sony SNC-RZ30N Network Camera Logo
1,952 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
