Question about Whirlpool Dryers
Model #WED4800XQ1 Whirlpool 29" electric dryer
  • 163 Answers
SOURCE: Whirlpool 29"gas dryer Model#LGN2000LW1
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
  • 262 Answers
SOURCE: dryer is not heating up,but its tumbling when turned on
with out being there this could be numerous problems like the simplest element,limit switch,timer or even the switch on the motor maybe you had a tech that was new but this has to be one of those that you go thur the circuits and find out what isnt working maybe call a smaller company like a independent some one that has to be on there toes to make a dollor than a company that just sends a face I dont know who you called but to fix this Anyone would have to be there to look at this one good luck and let me know what you find out
Posted on Jan 08, 2009
  • 47 Answers
SOURCE: ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Posted on Jan 21, 2009
SOURCE: Kenmore dryer not running
I have a 29" Kenmore electric dryer. Apx 4 years old. It runs but is not heating. What do I need to do?
Posted on Aug 03, 2009
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
How to change belt in whirpool washing machine model awg5052/m?
Go to www.repairclinic.com and enter the model number of your machine. You may be able to view a video that shows the whole process.
Jan 04, 2015 | Whirlpool WED4890XQ 29" Front-Load...
Whirlpool electric dryer WED4800XQ1 has power but
could be a bad thermal shut off thermostat or bad push start button, may even want to check the door switch
Sep 27, 2014 | Dryers
Electric Whirlpool Dryer . Model # WED4800XQ1 wont heat up and the timer wont work .
well you sort of answered your own question..You need a timer most likely, reason why it's not heating up could be because it's stuck in cool air cycle
hydeparkappliancerepair.com or visit us on Facebook
Mar 07, 2014 | Kenmore 500 6952 Dryer
Removing a part form a Whirlpool Electric Dryer
The thermal fuse is located on the outside of the blower housing. To get access to the thermal fuse you will need to remove the back panel of your Whirlpool dryer.
How do you check it:
Before you do any repairs on your dryer, you will need to disconnect the dryer from the wall outlet.
After removing the back panel, remove one wire from the Whirlpool dryer thermal fuse and take a reading between the two terminal on the thermal fuse.
The reading should be 0 ohms, if the reading is infinity, the thermal fuse is bad and it must be replace. When you find a bad thermal fuse, you will need to replace the operating thermostat too.
The operating thermostat opens at 155 degrees and the thermal fuse blows at 196.
These means that operating thermostat did not open at 155 and that is why the thermal fuse failed.
Jul 12, 2010 | Whirlpool Dryers
My 29" Whirlpool dryer runs but no heat.
This could be a thermostat, the heating element, or even a wire burned off (or loose).
Mar 31, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Dryers Logo
195 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
