Question about Samsung CLP-510 Laser Printer
Won't print dark black - areas of letters are gray and ...
Turn pale with more printing. all other colors appear to print fine.
i replaced the black toner, drum, and fuser. but still, black letters on white paper are not crisp dark like they used to be and have areas of gray turning to near white when continuing to print same job on numbers of papers.
  • 5 more comments
  • msb1100 Jan 23, 2009
    Already did that. No luck or change. Other colors have and still print fine, only black is faded through various portions of the page.
    hi,
    thanks for the comment, but there are no nozzles or print heads on this type of printer......
    Anybody can help?
  • msb1100 Jan 24, 2009
    Yep, used samsung parts
    help, does anyone know why clp 510 won't print black correctly?
    has a new toner in it, you think i rec'd a defective toner?
  • msb1100 Jan 26, 2009
    which roller is the transfer roller?
    if it was a voltage or roller problem , wouldn't it be a consistent problem with all colors?
    where can settings for colors be altered on this printer?
  • Samsung Master
  • 19,396 Answers
Hi, I fix this kind of stuff.
If you have light print, and you are sure is not a settings problem, then the problem is one of the parts below:
1 engine controller board or high voltage power supply or poor contact to the engine controller board.
This provides High voltage to the drum and fuser, if voltage is wrong you get light print.
2 Transfer roller is defective
In this case you get irregularly faded print.
I think this is problem related to high voltage board or connectors.
This is not a fix that you can do at home, reading the high voltage out is complicate and dangerous, and must be done by a technician.
Use the phone number listed on the owner manual to get support.
Posted on Jan 24, 2009
  • 535 Answers
U have to changed to toner net
  • sandip panchal
    sandip panchal Jan 26, 2009
    or u need to change the tonner
  • sandip panchal
    Sergeant:
    Champion:
  • 435 Answers
Hi, Did you replace with authentic Samsung parts?
Third party or used samsung parts might be creating the trouble...
Posted on Jan 23, 2009
  • 63 Answers
Im assuming this is from a print from a PC...
Does the same happen on a self test?
Let me know...
Matt
  • Boli Jan 23, 2009
    Sorry...
    Also have you replaced the transfer belt?
    Let me know...
    Matt
  • Boli Jan 23, 2009
    Transfer roller? as far as i can remember its seperate from the imaging drum...
    Let me know...
    Matt
    Genius:
  • 1,550 Answers
When the print cartridge contacts are dirty and the printer wont print properly.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
  • SAM ANDERSON Jan 23, 2009
    Have you tried cleaning print head . If not do this .
    Also check the nozzles are clear . If nozzles are clogged you will have this kind of problem.
    Have you tried taking test page after installing toner.
    Also check the settings in printer for minimum usage of black color .
My HP Photosmart C6380 all in One is now printing colour and black and white photos with a green/blue colour in dark/black areas of the photo replacing what should be black or gray. It never used to do...
To see which color is having an issue, go to printer control panel and select "settings" > Tools> Print report> Print Quality report. When the page prints out, you will see which color is the problem. After you have figured that out, make sure the problem is not with the cartridge.
If you see lines or missing colors, clean the printhead by removing it from printer(open cover, lift gray latch on the right side of the cartridges, remove cartridges and the printhead will easily slip out by pulling up)
then soak the printhead in half inch deep amount of window cleaning solution. Preferably warm. Let soak at least 3 hours. Dry out the printhead and wipe rear conacts from moisture and dirt. Reinstall into printer and see the results.
-Alex
303Electronics eBay Stores http://www.303electronics.com/
Jun 01, 2017 | HP Photosmart C6380 All-In-One InkJet...
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Samsung CLP-510 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
