Question about Exercise & Fitness
Got a powertrek treadmill when you push power switch on onkey pad just bleeps with era 2 message on display please help
3 Suggested Answers
georgiejm201
  • 54 Answers
SOURCE: my powertrek treadmill when switched
Typically when this occurs, it is an indication of a short circuit in the motor controller. Please follow the following steps to solve the problem:
First Test
1)Unplug the treadmill from the wall.
2)Remove the motor hood.
3)Unplug the speed wires from the controller. On many controllers, you will have 2 to 3 wires that control speed and many are labeled H, W, and L. If you cannot find the speed wires, do not guess, contact us with your make and model number and we will try to help you with the wiring.
4)Return the treadmill to a usable position once the speed wires are disconnected and plug the treadmill back in.
5)If the treadmill begins to run at full speed, the motor control has failed and requires replacement.
6)If the treadmill does not run at full speed you could have a speed input problem, wiring problem, or another short circuit.
Second Test
1)Unplug your treadmill from the wall.
3)Check and see if your controller has three speed wires labeled H, W, and L or a unified wiring harness labeled H, W, and L from the console. If not, you have a digital controller and full speed upon power up is always a failed controller. No need for further testing...you need to replace the controller.
Posted on Jan 11, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a proform fuel
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run without setting any value or witout safety key . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference. There will be a part like this in your treadmill's motor driver board. You can see the part number on it.
OK
Posted on Sep 01, 2011
I purchased a Manual Powertrek treadmill possibly approx 5yrs ago,lost the manual and there is no part number on the treadmill,how do i contact Powertrek direct,thankyou
go google and type in ---powertrek-- find their page that has a "contact us" section click on that and there should be an address, phone number, fax number and e-mail address.
Nov 07, 2016 | Health & Beauty
Tip
Oil service light
with all doors closed and ingnition off put one foot on brake pedal and one on accelaretor pedal push both of them to the floor at the same time once you have pushed them down hold them down to the floor and switch ingnition in the display it will say oil service in progresion after about 15 to 20 seconds you will hear a bleep and display will read oil service complete you must keep both feet on pedals and on the floor until you hear that bleep once it bleeps switch it back off release pedals and switch it back on oil service message would have been cleared
on Oct 02, 2011 | 2009 Ford Focus
Domyos Tradmill just Bleeps when turned on
adjust the REED switch, see the diagram attached. Clean it+test for open or faulty +tight the connector very well.
Jun 09, 2013 | Exercise & Fitness
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
My treadmill lights up but when i push start it dose not go on
please adjust the REED SWITCh, see the diagram attached, clean it, and tight the wires connector.
2) tight the ribbon cables for keypads switch, tight the wires connector from display board vs lower board.
3) try to LUBE the deck belt accordig with the instr. manaul
4) lube the rollers bearing.
5) test the motor voltage input, if there are the motor NEED repair.
6) measure the output voltage board, for input voltage board, if there are NOT, the board is faulty. see the diagram attached.
God bless you
Jul 30, 2012 | Exercise & Fitness
I have powertrek treadmill and the powerlight on the rear switch is on but no display power or reset button. There is a fuse next to powerswitch that says f12al250v. What amp would that be??
1) see the block diagram attached and proceed.
2) Adjust the REED switch, clean it, and tight the wires connector v. well.+tight the ribbon cables, tight the wires connector v. well. vs lower board wires connector
God bless you
Jul 10, 2012 | Exercise & Fitness
Powertrek treadmill jerks to start and straight away to stop repeatedly. what can be a problem?
1) ;LUBE THE DECK BELT very well, this a sign for a deck worn.
2) lube the rollers bearings too.
3) Measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram
Good Bless you
Jul 03, 2012 | Exercise & Fitness
My powertrek treadmill when switched on goes straight to full speed & will go at this speed only
First Test
Second Test
Jan 11, 2011 | Exercise & Fitness
How do i tighten and centre the belt on POWERTREK
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 13, 2010 | Exercise & Fitness
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
