Question about Hobart ET27 4-Slice Toaster
Hello, I am looking for a part for my Hobart Toaster
    Scholar:
  • 109 Answers
Www.hobartservice.com
select parts on left side of the screewn, then select your model from the list,
or use the HL number on the data plate to go to the correct parts catalog with part numbers.
Posted on Aug 13, 2009
    Problem Solver:
  • 13 Answers
Parts books are available at hobartservice.com for free and the locations Hobart offices for parts
Posted on May 09, 2009
Hobart toaster et27 one side does not work. Tested all elements, all showing resistance. 125V at all terminals when control is down. I am stumped
Check for corrosion at the contact points.
I suggest not "fiddle" with a toaster and instead replace it for safety reasons.
Nov 28, 2017 | Hobart Kitchen Appliances - Others
Hamilton beach toaster T75
No not if its one made for USA with 110 volts. They do sell adaptors for travelers. So they can operate in different countries.
Mar 29, 2014 | Hobart Kitchen Appliances - Others
The hello kitty face side of the toaster doesnt heat up, when i look inside, it looks like the heating strip is diagnal not horizontal like it should be
it sounds like the element broke, which they do. this is not really repairable in a general sense. You might try the Chococat toaster.
Jun 25, 2011 | Sanyo Hello Kitty (SKKT2P) 2-Slice Toaster
Just i wonder this toaster work whit 120 v. and how
It's a commercial grade toaster designed to run at a minimum of 208v on a 60Hz supply, but more usually operated in the 220-240v range. To run it at 120v requires a power inverter with a high current output, most inverters are designed for low current devices.
In practical terms, it's not a realistic prospect when there are already so many other commercial grade toasters which do exactly the same job at a native 110-120v range.
Sep 22, 2010 | Hobart ET26 – 4-Slice Bread Toaster
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
One side will not heat
check your timer board at the back of unit
Nov 27, 2008 | Hobart ET27 4-Slice Toaster
Toaster Parts hobart ET25-27
goto hobartcorp.com find your model then the part or call 18884hobart
Aug 14, 2008 | Hobart ET27 4-Slice Toaster
Hobart ET27 4-Slice Toaster Logo
137 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
