Lexmark X1270 All-In-One InkJet Printer
Problem for Lexmark X1270 All-In-One InkJet Printer
Problem communicating with the printer
By twasho on Jul 08, 2007
when I first installed the printer software it worked fine when I disconnected the usb fromt he laptop and then reconnected it windows prompted me to install again I cancelled this step as the software ws already installed, but it kept prompting me to install. I did reinstall because I was getting error messages that the software was not fully installed. by this time there are two printers installed but when I try the print from either one it says failure to communicate with the printer. It will scan but not print. I has to uninstall all the printer software and reinstall. I can't keep installing the software everytime I connect the usb cable up is there anything i can do?
Same Problem
Feb 03, 2008
-   my printer is not communcatng with the laptop
-   karsana
Jan 21, 2008
-   I have the same problem, I have the lexmark x1290 running with vista. I can't get the printer to communicate with the printer at all. I call tech support but the wait for help is 20 min.
Please help
Do I need a different driver to communicate with Vista Operating system
-   coolbrie
Jan 19, 2008
-   Same here. Sent my lap top to the shop to be fixed and now printer will not recognize it. I will try the advice given.-   Makeba35
Jan 12, 2008
-   I know just what you mean because it happened to me too. I unhooked my printer and when i hooked it backup it would NOT work.-   carolyncca1
Nov 26, 2007
-   My printer use to work .I could print things from the computer.I just moved in to my new house and now the computer is not working.I have tried unpluging the usb cord and restarting the computer and I am not able to print.
-   Guest
Best Solution
posted on Jan 10, 2008
Helpful)
tonysmith
Rank: Wiz
Rating: 81%, 151 votes
Which printer do you want to keep always so go to menu/printer & faxes and then select the printer which one you want to always use click the right button and select the default printer.Ok!!
Thank you
Tony
Comments:
Jan 13, 2008
- U have share the printer for three user ok.
Was this helpful?
Yes
No
Solution #2
posted on Jul 10, 2007
Not Helpful)
jackboy
Rank: Wiz  Lexmark Expert
Rating: 77%, 4370 votes
This is a problem for folk with lappies who disconnect and the Windows prompts to reinstall each time.
I don't know a simple answer .It is a Windows problem not the printers
So cancel one printer installation and leave the original.
Try to cancel the prompt when it comes up again.
or take the software right out and plug the printer in. then when the prompt comes up- ignore the CD and select the 'select from list'
Choose the make then the model.
When closing down windows only remove the printer when the computer is shut right down.
and plug in before you fire it up.
Then the computer will not know it has been without.
Was this helpful?
Yes
No
Solution #3
posted on Nov 04, 2009
Very Helpful)
vj Koganti
Rank: Apprentice
Rating: 100%, 1 votes
Ok Guys! I found the solution to the nasty "Problem communicating with the printer" AT LAAAST !
I have a lexmark 2480 and I recently upgraded to windows 7 ( I had the same problem with Vista earlier as well) so this problem has nothing to do with your operating system. The mistake I was making was that I first connected the cable and then began installing the setup.exe file. I never got the printer to work after that though strangely the scanner seems to work. I even enabled bidirectional port but it was no help. I tried unchecking the check box that said "save power...." in the usb port device I accessed using the device manger. No. Nothing works.
Finally I found the answer. I uninstalled lemxark. I disabled the firewall. Then Disconnected the cable. Guys this is important you have to disconnect the cable and then only hit setup.exe. You must connect the cable only when the setup asks you to. And it works. I used the setup in my CD which I got when I bought the printer. Despite the fact that my OS is windows 7, 64 bit all works fine!
take care, hope this helps people like me who had to tear my hair apart for 3 hours+.
VJ Koganti
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Mar 19, 2009
Not Rated)
nazabe
Rank: Apprentice
Rating: 0%, 0 votes
I deleted McAfee firewall and the printer worked again.
Was this helpful?
Yes
No
Solution #5
posted on Dec 11, 2008
Not Rated)
ohoraherecap
Rank: Apprentice
Rating: 0%, 0 votes
I've installed and reinstalled a few times but still getting the messae that there is a problem with the printer communicating with the computer.
My printer is a Lexmark X1100 and my laptop is an Advent 5311.
Should be simple but can't get it to work.
Look foward to hearing from you.
ohoraherecaptain.
Was this helpful?
Yes
No
Solution #6
posted on Sep 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
RESOLUTION loadTOCNode(1, 'resolution');To resolve this issue, follow these steps: 1. Click Start, right-click My Computer, and then click Properties. 2. Click the Hardware tab, and then click Device Manager. 3. Expand Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties.
Note There may be more than one USB Root Hub installed in your computer. In this case, you may have to follow these steps with each USB Root Hub device. 4. Click the Power Management tab, click to clear the Allow the computer to turn off this device to save power check box, and then click OK. 5. Quit Device Manager.
Popular Solutions for Lexmark X1270 All-In-One
Questions and Unsolved Problems for Lexmark X1270 All-In-One
Do you recommend Lexmark X1270 All-In-One InkJet Printer?
Answer
Answer
i can't locate the scanning software on my laptop for my lexmark x2600 printer/scanner
Answer
i can print from my pc but not from on-line when i print from on-line all i recieve is the date and... (More)
Answer
I put in a new colour ink in and it only wants to print the colour yellow? I cleaned the jets many... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lexmark X1270 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
