Question about Canon DR-2580C Path-Through Scanner
The scanner pauses half way throught the document
Using Canon DR 2580C the scanner pauses about half way through scanning the document and then will continue scanning but it does that on almost every page. However the confusing piont is that it is not a consistent problem and none of the settings have been recently changed. Help please!
Make sure you are using USB 2.0 I have seen this issue several times, you may need to reinstall your chipset drivers. I have had this problem on 5 different computers and all were related to reinstalling the chipset drivers. Cannot explain why, the computers were not having any other issues just pausing during scanning. We have 50 of these scanners, they work well when the tires are clean.
Posted on Jun 17, 2010
  • 490 Answers
May be the location where it is writing the data is not 'free'. Do a 'deframent' of the drive where you intend saving the data. Ensure there is enough space on the Hard Disk
S. Mohan, Chennai, India
Posted on Feb 17, 2009
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
Black at the bottom of scanned pages
There should not be a thick black line at the bottom, but could be from several things, light coming in from somewhere is my first guess, toner is almost out or the ribbon is getting stuck on the inside at that point. You may have to call Cannon and ask them.
Aug 21, 2009 | Canon DR-2580C Path-Through Scanner
Dr-2580C nolonger pulls one page at a time.
How old is the rubber roller, in terms of number of scans? It it had crossed 250,000 better change it. It wears out and no amount of cleaning can help. Ensure that the paper is not sticky. Stapled documnets are held together where the pis was, ensure they are free.
Mar 19, 2009 | Canon DR-2580C Path-Through Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
Oct 14, 2008 | Canon DR-2580C Path-Through Scanner
Canon DR-2580C Scanner
You must have 'checked' the multipage option in the scanning software. Try scanning first page only and store as say temp1 and later all pages as temp2. If the file size is different you can deduce that the scanner has scanned all pages! To view multipage files, you need a proper software.
S. Mohan, Chennai
Nov 29, 2007 | Canon DR-2580C Path-Through Scanner
Image problems
The lower scanner unit moves when doing the shading adjustment (scans the little white plate on the top and bottem scanners). Most common problem is a staple interfering with the lower scanner movement.
Oct 02, 2007 | Canon DR-2580C Path-Through Scanner
Canon DR-2580C Path-Through Scanner Logo
442 people viewed this question
old marine
old marine
